My wireless antenna is in and the thing says does not exist
    Guru:
  • 382 Answers
You need to make sure the drivers are installed for that device. If you talking about an external wireless card, I believe it came with an installation disc. Run the disc and your wireless card will be detected by your computer and is ready to use.
**comments, suggestion and rating will be greatly appreciated
thanks!
Posted on Sep 15, 2010
Testimonial: "your very good ty"
Router connection
The problem is not the antenna.
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 13, 2012 | Computers & Internet
I have purchased TWO Packer Bell ixtremeI5726 with a wireless keyboard and mouse. The keyboard and mouse have come equiped with a wireless antenna which is screwed into the wireless card on the back of the...
The antenna that you found is purely for the Wireless LAN. The Keyboard and Mouse are already paired with the bluetooth receiver. This is "HIDDEN" in the mouse battery compartment. But not where you'll see it... it is in the LID of the compartment.
May 30, 2011 | Compaq Keyboard
WEAK signal :-( How do I extend the distance or wireless reach.
Either look into getting bigger (higher gain) antennas for your router, or get bigger/stronger antennas for your PC's.
Other than repositioning the existing antennas or putting the router higher up in the air, there isn't much you can do.
May 26, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Extend Range ?
The best way to extend a wireless signal is to get a wireless range expander/extender , because a high gain antenna really give the needed boost of wireless signal.....
Don't forget to rate the solution FIXYA thank you............
Oct 16, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Distance from TX to RX possible too great
There are a couple more questions
  1. Is it a removable antenna on the wireless router e.g. 5db or 7db gain. you could just get better antennas to increase signal strength for distance.
  2. E-bay has a linear antenna you assemble with a usb wireless network adapter attached.
Mar 31, 2008 | D-Link AirPlus DI-524 Wireless Router
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
Replacing antenna on linksys wrt54g router
yes u can get a antena from retail store and get it and remove the old one and turn off the router and and connect the new one and turn on the router>rate me solved if its helps thx
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Not enought signal
Ok there are a few ways to increase ya signal strength... One can purchase an antenna that has a high "Gain" and connect in place of existing antenna.. One can place the Existing Antenna in "Optimal Positions".. ie: Up High with an Unbroken Line Of Sight between Antennas. One can sometimes increase the Output from your WiFi adapters.. you must check any documentation to see if this is possible. One can make a thing called a"Cantenna" here ---> www.turnpoint.net/wireless/cantennahowto.html There are "Other" Home made antennas that are cheap and easy to make, some simply made from cardboard and tin foil. The most important thing to remember is, Antenna Placement for best signal strength, with least amount of obstacles in between units, & up as high as practicable..
Sep 04, 2007 | NetGear WPN111 RangeMax Wireless USB 2.0...
Where should I place my router?
This describes moving equipment, positioning antennas, and avoiding obstacles. When optimizing your existing equipment, consider: * Placing antennas in a good location, at a good angle. * Avoiding physical things that block signals. * Reducing the interference from other things that transmit radio waves. Before starting adjustment, make sure that antennas and cables are securely fastened! If your network has more than a couple wireless devices, before you move things, decide which wireless devices are transmitting the heaviest load. These links are important to optimize. NETGEAR products have automatic data rate fallback, which allows increased distances without losing connectivity. It also means that devices that are further away are inherently slower. Therefore the most critical links in your network are those where the traffic is high, and the distances are great. Optimize those, first. The ones that are least important are links that have little, occasional traffic, and which have a strong signal strength. Picking Good Locations for Antennas * Antennas should be in line-of-sight of one another, where possible. Put your face next to one antenna, to find whether the other is visible. * Place high, and clear of obstructions as practical. * Keep antennas 2 feet from metal fixtures such as sprinklers, pipes, metal ceiling, reinforced concrete, metal partitions. (However, antennas on roofs do not necessarily give the best results. ) * Keep away from large amounts of water such as fish tanks and water coolers. * Antennas transmit weakly at the base, where they connect. So don't expect good reception from the bottom of a router or access point. * For multi-story buildings, placing antennas at 45 degrees (diagonally) or 0 degrees (straight out parallel to the floor) may be most effective. Reducing Interference Avoid windows unless communicating between buildings. (Windows let in interference from the outside world.) Place antennas away from various electromagnetic noise sources, especially those in the 2400 ? 2500 MHz frequency band. Common noise-creating sources are: * Computers and fax machines (place wireless equipment no closer than 1 foot) * Copying machines, elevators and cell phones (no closer than 6 feet) * Microwave ovens (no closer than 10 feet)
Feb 19, 2006 | NetGear RP114 Router
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
