My printer wont turn on , and i need it right now!
  • Paul Lyman
    Paul Lyman Sep 15, 2010
    Is it plugged into a working outlet?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
Please follow the instructions given below:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
Please try to print the self test
From Jeethu
Posted on Sep 15, 2010
My hp deskjet 2050 printer cartidge carrier wont move to the left side and all light blinking?
Turn off the printer. Remove the cartridges and try moving the carriage manually from right to left or left to right 5-6 times. There can be mechanical issue if it does not move even when the printer is off.
Regards,
Sean
Oct 02, 2013 | HP DeskJet Office Equipment & Supplies
My epson stylus nx125/127 series priter wont turn on i have already checkd all the cords everything is plugd in right i disconected it for about 5 days and it still wont turn on
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
May 11, 2011 | Computers & Internet
Computer says paper jam, the paper jam was cleared from the printer, but still wont print
turn printer off for 5 minutes, while waiting go to ->Run->type "services.msc" Right click on "print spooler" and restart Turn printer back on
Mar 05, 2011 | HP Officejet 4315v All-In-One InkJet...
Wont print
go into the printer/control panel/ printer right click preferences /open and cancel all documents that will delete the hold. Check the usb connection sometimes that will come loose Do you hear that hardware connect noise when you turn the printer on?
Feb 13, 2010 | Office Equipment & Supplies
The ink cartridge wont come to center
Turn of printer. Turn it on, watch the carriage move, when it goes to the other side quickly unplug your printer, it should stop somewhere along the middle of the printer, now u can freely move it by hand to the position that you wanted, you can now remove the cartridge and replace it with a new one, after doing what you need to do just push the carriage towards the right side where it should be parked. Good luck!
Jan 14, 2010 | Dell Office Equipment & Supplies
The printer turns itself on autamaticcally and wont stop printing
You need to cancel all pending print jobs on the queue. If you see the printer's icon on your System Tray, lower right corner of your computer, right click it and choose Cancel Print Jobs. Or you can double click it so that it will show you the current printing job or those in queue. Select and delete them. If this does not cancel the pending print jobs, disconnect your printers power cord and shutdown the computer. After like 10 minutes, turn the printer and computer back again.
Dec 01, 2009 | Dell Office Equipment & Supplies
Just moved. New laptop. Computer says 2 pending printing jobs but wont print. Message from printer: "ofline" Help
You may try the following suggestions:
  • While it says offline, right click the printer icon and cancel print jobs.
  • Right click the icon again, then 'Set Printer Online'.
  • Power cycle the printer. Just turn it off and then turn it back.
  • Reinstall the printer by running the 'Add Printer Wizard' and let it automatically find your printer to be reinstalled.
Nov 02, 2009 | HP Officejet 4110 All-In-One InkJet...
Printer failing to print
start --> run --> services.msc
press enter / click on ok
scroll down to print spooler and right click on it and click on restart and then go back into printers and faxes and right click on printer and cancel all documents or delete the print job
If that fails to work you may need to use the utility that came with your printer to cancel it - short of that you can just turn the printer off for about 5 seconds and back on.
May 25, 2009 | Lexmark X3550 All-In-One Printer
I have got a problem with my printer hp photosmartc4180 series it wont let me print i try different situations now i have contacted hp they say it needs cleaning by compaq
What happens when you try to print?
1. When you try to print do you see the printer icon on the taskbar? (lower right)
2. Do you see the printer in your printers folder?(start/settings/control panel/ printers) Might need installed
3. Is the printer your default printer? (right click on the printer in the above area and select "set as default printer")
4. Is it plugged in, turned on and plugged into your computer?
5. Has the software been installed or recently updated?
Let me know if this helps
Dec 31, 2008 | Computers & Internet
I installed my printer and it till wont work.It say's the printer is busy,and that there is no communication.
hmmm..ok...
turn off printer
unplug from computer
turn printer back on
plug back into computer
try a test page, from printer panel(right click on printer, properties)
Jun 22, 2008 | Lexmark Office Equipment & Supplies
66 people viewed this question
jasbo
jasbo
