Question about Dell Inspiron E1505 Notebook
Dell e1505 I need to replace the headphone jack (speakers work when you jostle the plug) can you give me a part number. Or maybe include me in a secret you have? Thanx!
    Sergeant:
    Champion:
  • 305 Answers
If your on about the headphone socket its on the motherboard so probably cannot be repaired by you they can be repaired but its expensive usually about £100 sorry.
Posted on Sep 15, 2010
My dell latitude d510 internal spk is ready but output headfone jek not working
these are fairly passive in that if a headphone or earpiece is plugged in, they switch the output from the internal speaker to the external speaker. So, it's usually one of a few problems.
  • The jack is mucked up, and needs replaced.
  • The headphone plug wires have a broken connection
  • The headphone needs power to amplify, and that's not working.
If trying another headphone or earpiece you know is working doesn't work, it's the jack itself. They can only handle so many uses before they either fail closed, or open or completely. Depending on which one, either:
  • neither speakers nor headphones work.
  • only speakers work
  • only headphones work
Replacement necessitates opening the case and replacing the jack. For that, there's no help.
Sep 02, 2015 | Dell Latitude D510 Notebook
Headphone jack not working on dell d810
andys_cars,
You may need to go into the sound properties and then to deviceto change the settings to enable the speakers and change it from headphones to speakers.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 04, 2013 | Dell Latitude D810 PC Notebook
How can I get headphones to work with my Symphonic WF203 TV?
This set doesn't have a headphone jack, nor does it have RCA audio output jacks. Without one or the other, you're out of luck connecting headphones to this TV.
I remember a product some years ago that allowed adding headphones using a small microphone placed in front of the speaker. This was hooked to a little amplifier that ran the headphones so the volume could be independently controlled. It was marketed as a way to let "hearing-impaired" family members listen to TV shows without needing to make it uncomfortably loud for others. I haven't looked, but something similar might still be available. It's cumbersome, though, and needs power, plus maybe being costly if you find one.
It's possible to add a headphone jack, but you need to know how to do electronic soldering. Find a spot on the case where you can make a hole and mount a headphone jack, then wire it to the speakers. If you want the headphones to cut off the speakers when plugged in, you need a switching jack, and the speaker wires need to be cut and connected to the correct terminals. The switch built into the jack then disconnects the speakers when the headphone plug is in. If you don't need to turn off the speakers it's a little easier. You just need to wire from the jack to the speaker terminals. I've added jacks on quite a few sets. If you don't feel up to it and don't know anyone who is, you can see if a TV shop (if there are any left in your area!) would do it. (The shop I used to work for charged about $20, including the jack, but that was over 10 years ago now.)
Good luck, and thanks for using Fixya!
Jun 12, 2011 | Symphonic WF20D4 TV
My dell inspiron N5010 's internal speaker is not functioning..but i can hear through my head phones
The problem is in the earphone jack, when you plug headphones into the jack it dis-connects the internal speaker. Since you can hear the sound through the head gear, it indicates the jack is defective and needs to be replaced, or it needs a good flushing of electronic contact cleaner, attach the supplied straw and aim it in the jack and spray, next take the headphone jack and push it in and out quickly, repeat the process three or four times, If this fails the laptop will need to be dis-assembled for continued repair.
Jan 21, 2011 | Dell Inspiron 1525 Laptop
Can you connect single behringer powered speaker to dell desktop
if you are good at wiring you could take old headphones and use it and plug it into the headphones jack and have it work without frying it but if you arent good at wiring dont atempt to because it could hurt the powered speakers or the computer
Mar 14, 2010 | Behringer Eurolive B212A Speaker
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Headphone jack loose?broken?
You need a new one not worth fixing
how old is it when did it stop working
if you just bought it then
you need to return it and have it exchanged
there obviuosly is a defect.
Feb 12, 2009 | Dell Inspiron 6000 Notebook
Dell E1505 internal speakers not working
You have verified that the sound card and drivers are working, by plugging in externals. This leaves only the speakers. Check and clean the speaker connections, they will sometimes work loose or get a little dirt/corossion build up. If the connections are good, then you will need to replace the speakers.
Jul 30, 2008 | Dell Inspiron E1505 Notebook
Dell 610 lptop - haedphone not working,
First try uninstalling the sound drivers from the device manager, then reboot. It will find and reinstall them, then check Dell's support site for updated sound drivers. If you find updated drivers you will need to use the update button for the device in the device manager. If this doesn't work, then it may be a faulty headphone jack. The jack should override the speakers when the headphones are plugged into it. If you can still hear the speakers with the headphones plugged in then the jack is faulty and needs replaced. If the jack does override the speakers or if you get some static then it could be that the jack has come loose or has a loose or broken wire. The only other thing is try a different set of headphones, sometimes laptops get picky and one set will work and yet another set may not.
Jul 02, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron E1505 Notebook Logo
177 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
