Hi. i have my SHARP ESS1251FP automatic washing machine with anti-bacterial thing. just recently, i cannot control the water supply even if the water level is already okay/full. i think the water stopper isn't working now properly. that's why i have to turn off the water from time to time which supposedly isn't normal. what should i do to control and stop the water especially during spin drying? what's wrong with the machine?
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
jan mczeal
  • 632 Answers
SOURCE: M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 22, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
SOURCE: Washing machine has a seizure during the spin cycle.
Hi, I had the same problem. When i went on the frigidaire web site, i saw an F&Q section. Make sure all of the shipping packaging is out of the machine. I left on the the yellow "p" hooks and bolts. Once I took them out, it ran perfectly.
good luck!
Posted on Feb 24, 2010
I have a Maytag MAV7700 washer. It can fill with hot or cold water but when warm is selected it doesn't appropriately mix them to get a warm temperature even with the automatic temperature co
Hi etjacobsen.
As 'warm' is a mixture of 'hot' and 'cold' water a simple remedy to your problem might be to reduce the flow in the tap supplying the machine.
Good luck.
Nomess
Jan 12, 2015 | Maytag MAV7700 Top Load Washer
Hi, The last two washes i've just done on my Hotpoint WD72, the washing has gone full cycle but has come out smelling damp. Any ideas? I've had it since 2005 when it was new.
This will potentially sound odd, but run the 90 degree cycle with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 26, 2011 | Hotpoint Ultima WD72 Front Load...
Keep having sour smelling clothes - pair about 5 years old. HELP! W6021 Quattro 1200 RPM
Jul 19, 2011 | Asko W6021 Front Load Washer
Washing machine drum always smells of stale water. Have tried hot washes, washing machine cleaner kits, cleaning filters, leaving door open, have also checked machine is correctly plumbed in but cannot get...
Jul 12, 2011 | Whirlpool Washing Machines
Foul smells coming from my washing machine DRUM
Jul 07, 2011 | Indesit Washing Machines
I have a WD1 12C Smeg washing machine - when I open the door there is an awful smell reminiscent of stagnant water - the machine it self seems to be running OK I've put it on 90degress empty but still...
This will potentially sound odd, but run the 90 degree cycle again with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 07, 2011 | Smeg WDI12 Front Load Washer / Dryer
The washing smells of dirty water, have tried all sorts, but cannot get rid of the smell.
Several things to try:
Check the empty pump filter, that may be clogged with smelly debris
Ensure that the empty pipe is correctly inserted into the drain pipe and that there is a trap on the drain that stops smells coming back
Finally (This may sound odd) with no clothing in the machine, throw 3 dishwasher tablets in the drum and run it through the hottest cycle the machine can run. Smells can often be bacterial caused by biological washing powder which builds up bugs in the machine. Dishwasher tablets are anti-bacterial and will kill the bugs.
Jun 30, 2011 | Washing Machines
My Sharp Washing Machine ES-6515TS still drains even if the drain control is already closed and sometimes water goes out to the spinners tub.
PROBABLY THERE ARE THINGS THAT BLOCKING THE DRAIN, IT MIGHT BE COINS, PARTS OF CLOTHES, PANTY OR HANKY. SIMPLY OPEN THE BACKSIDE OF YOUR WASHING MACHINE, UNSCREW THE DRAIN LINE COUNTER CLOCK WISE TO OPEN THE VALVE FOR DRAIN. YOU'LL BE AMAZED OF THINGS PRESENT INSIDE THE DRAIN VALVE. AFTER THAT IT WILL BE OK FOR YEARS. I BROKE MY SPIN DRY MOTOR AND RUBBER BELOUSE, FUSE 3X. SHARP TECHNICIAN CAN'T FIND THE PROBLEM WHICH I DID AFTER 5 YEARS. I HOPE IT WILL BE HELPFUL TO YOU.---ROMMEL OF MANILA PHILIPPINES.---rtlagasac@hotmail.com
Jan 09, 2011 | Washing Machines
Ge washer won't stop draining water even before
Try these
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Pls rate my suggestion...
Jul 23, 2009 | GE Washing Machines
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
