Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Programed garage door pad with 4 didgit number and remolts and go to push remote and it clicks like it wants to go down but it does not changed all batt
    President:
  • 3,197 Answers
It sounds like your door sensors may not be aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit.
Posted on Sep 15, 2010
I just installed a new Genie Silentmax 1000. The wall switch works. The up and down settings are right. The safety doors sensors are working. My problem now is that I can't get the remotes or the key...
On the back of the garage door opener there will be a button that you will push it will start flashing right then you will push the garage door opener button and do the same freaking packed push the button wait for the blinking light enter your code and pushed enter
Feb 16, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
How do i change the numerical code?
How to change or program code on your Craftsman Liftmaster keyless keypad made by Chamberlain.
1. Program using the "Learn" Button
2.
Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Program using the Multi-Function Door Control
NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
  1. Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
  2. While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control. Both of these should now be held down at the same time.
  3. Continue holding the ENTER and LIGHT buttons while you press the push bar on the Multi-Function Door Control (all three buttons are held).
  4. Release buttons when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Change an Existing, Known PIN
If the existing PIN is known, it may be changed by one person without using a ladder.
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  2. Press the new 4-digit PIN you have chosen, then press ENTER.
The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN, then press ENTER. The door should move.
Your new Keyless Entry must be programmed to operate your garage door opener
May 24, 2011 | liftmaster 977lm 976lm Liftmaster...
Bought house with craftsman garage opener. Owner only had one remote. Bought a new remote at Sears that matched color code. followed instructions to code remote...that worked but made the old remote non...
Post the model number of the opener and the model numbers of the remotes. The opener model number is found on the end closest to the door and starts with 139.
Try programming the keypad like this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
After programming the keypad see if either remote will work with it. Post this information also.
Oct 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
I don't have the manual to re-program my keyless entry pad and cannot use it. The previous owner did not keep the manual and on occasion, he comes back and goes into the garage. He is in his mid 80's and...
You may need help with this if you cannot get up on a small ladder.
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Two codes open door
You must hold that red button in for 6 seconds to erase the memory. Just remember you will have to program your hand remotes plus the wireless keypad.
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless Keypad wont allow use of other door openers
hit learn button for 10 seconds. now nothing will work except wired buttons. Hit learn for 1 second and put in yur 4 digit keypad code and hit enter, light on motor will blink twice. hit learn again for 1 second and push button on remote. again bulb will blink. continue pushing learn for 1 second and adding another remote.
Dec 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Changing PIN on Key Pad
can you please provide the exact model number of your Security device...
Thanks
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door keypad/remote programming problem
Hi All,
I had the same issue recently and here's what I found out (through a LOT of research) and the solution (yes, there is one!):
As described by many, when you can't get both the remote and the wireless pad to work together it means your garage door opener can accept both rolling code and billing code technology, BUT not at the same time. When you reset all codes (normally by pressing a button on the opener for a period of time e.g. 6 seconds or more), you erase all codes and remote "pairings". Then when you follow the manufacturer's procedure to pair again (which could be the wireless key pad first OR the remote first), the first pairing determines the technology for all subsequent pairings. Example: if your first pairing/programming was with the wireless keypad, and if it was rolling code technology (normally the case for newer models), then the garage opener will only recognize and accept rolling code for subsequent pairings. If your remote(s) are older (billion code technology) then the opener won't even recognize the signal (e.g. led won't blink when trying to pair/program).
And vice versa if you start with your remote after erasing all programming (then your keyless pad won't work).
But here is a potential workaround! For newer wireless keypads (e.g. clicker from chamberlain), you have an option to select the type of opener you are using as you do the initial password set up (normally indicated by a number e.g. 1 for models built after 1995, 2 for models built between 1997 and 2004, etc). Each choice is associated with a technology in the background (e.g. either rolling code or billion code). If you are programming your wireless keypad first after erasing all codes / programming, if you chose the "recommended" option for garage opener, chances are it will be rolling code and that means you won't be able to program your older remotes (billion code) after that. So how can you chose the option that will match your remote???
Here's what you do: start by pairing / programming your older remote first after erasing all codes / programs. That sets the technology (e.g. billion code). Then, go ahead and program your wireless keypad, but you may have to go through the process several times by trying the different options until you find one that works!
For me, I had to try 4 options before making it work. Options 1 through 3 (mind you, options #2 was the exact match for my garage door opener model but it would cause the problem discussed here e.g. wireless keypad would work but not the remotes) would not even be recognized by the opener in this procedure (LED would not blink), but it did work once I hit option 4.
I hope this will help you with your problem. Let me know if it's not clear. Cheers!
Jun 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
29 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
