Question about Waring WMK300 Professional Belgian Waffle Maker
How do you remove the griddle part from the base for cleaning?
Dishwasher on heavy cycle, just put the whole thing in. Trust me. I am a man in the Lord.
Posted on Aug 12, 2012
Are there any good chemical free products to clean my grill pan with?
I'll let you in on a little chef secret: White onion! Cut an onion in half, stab the round part with a fork. Heat up the pan or griddle and rub the onion across it. This will help remove all the gunk that gets stuck there.
Jan 10, 2013 | Home
Food sticks to griddle
You can either use a cooking spray like Pam on the griddle prior to heating it. Or if you're cooking steaks, rub a little olive oil on each side of the steak, before seasoning (kosher Salt & Fresh Ground Pepper) it. For meats, always allow them to come to room temperature before grilling and allow the grill to preheat until is extra hot. The hotter the grill/griddle, the less likely red meats will stick to it.
Hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Aug 12, 2011 | Coleman Roadtrip Grill LXE 9949-750
How do I season the griddle that came with my new gas stove?
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
How do I clean a Viking griddle that hasbeen
I use a product called Greasecutter Plus by ECOLAB, it makes the griddle look brand new, gets everything off. You just spray it on and let it set for a little bit then it wipes clean.
May 13, 2010 | Viking Cooktops
Is there a cleaning manual for my 6 burner/griddle viking range?
I have a product that I use to clean my burners and griddle with, it is made by ECOLAB and is called Greasecutter Plus. It doesn't hurt the range but it makes it look brand new, even my griddle comes completely clean. You just spray it on then let it sit for a bit then it wipes clean.
Apr 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Cleaning the cast iron grates and griddle
Take the grates off and slide them on your dishwasher rack and run them thru a cycle... pull them out before dry if you want..
May 31, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Need to replace griddle thermostat
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
Apr 15, 2009 | Viking VGSC306-4B Gas Kitchen Range
Cleaning the stainless steel griddle??
We buy DeBruce Polish at debruce polish.com this stuff really works!!
Mar 28, 2009 | Thermador Professional Series PO301...
Griddle burner wont spark
Make certain the burner and burner base are very clean by carefully washing in warm soapy water, using a plastic brush to scrub any residue off the surfaces. Also clean the spark ignition nub in this same way.
Jan 23, 2009 | Rangemaster Proffessional 110 Gas Kitchen...
How to clean electric griddle
Hi there!
When it is warm, use a spray cleaner and paper towel to wipe up the grease.
Wooden or non-stick spatulas make excellent scraping tools to take the worst off first.
Use paper towel to wipe up.
For really stubborn deposits, use an oven cleaner - and cover with plastic film. Check in 1 hour, and clean as above.
Soda Crystals dissolved in hot water are excellent at cutting through grease, but may affect aluminium. They work out cheaper than many commercial products.
Hope this helps you.
Jun 01, 2008 | Kitchen Appliances - Others
Waring WMK300 Professional Belgian Waffle Maker Logo
100 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
