Question about Cobra 25 LTD 40-Channels Base CB Radio
How far can I get this thing to reach,and how ?
    Guru:
  • 773 Answers
With a good antenna, and the antenna tuned for best SWR, about 8 miles from mobile to mobile, and about 12 miles from mobile to base radio.
You can modify the radio and turn up the power, it will get you more range, and make the radio sound louder, but you will still be limited, because radio is line of sight. Hills and structures block RF signals. you go down a hill, you will loose distance.
With a cobra 29 that has been tuned up sitting on a hill about 1400 feet above sea level, I was able to talk to some one on a base radio about 50 miles away with out my amp on. I also have a very very good antenna. not something you normally see either.
With a clear on blocked line from antenna to antenna, you can talk really far on a stock radio. There is a saying for CB antenna's. "Height is might."
There are a lot of things that effect the distance a CB can reach.
If there is Skip active, you can possibly talk thousands of miles with a stock radio. Skip is when the ionosphere becomes charged by solar energy form a solar flair and causes the radio waves to bounce off them, making it seem like you have a straight line of sight to places that would normally be blocked by the natural curvature of the earth.
Then there are Linear amplifiers. They increase the power of the signal of the radio. They will increase the output range, but then you may be talking to people that don't have an amp, and that you will not be able to hear them because they do not have enough power to reach you.
So, get a really good antenna. Make sure it is tuned for the lowest possible SWR. Refer to the manual that came with your radio on how to find out your SWR, and how to lower it. There will also be instructions on how to tune the antenna that came with the antenna. Then bring the radio to a CB shop or a CB tech and have them tune it up. It will cost about $30.
With my radio barefoot, and can normally talk around 30 miles or more without worrying about hills and obstructions. (Barefoot means, without the amp on)
Posted on Oct 07, 2010
When I use the Bontrager super charger pump on a Presta valve I get up to about 45lbs and it releases and deflates the tire. What I am I doing wrong here?
You are probably pushing the pump on too far before clamping it onto the valve stem, thereby keeping the valve pressed down/open. Once you reach enough pressure the pump can't hold on any more. Put it on just far enough so it clamps on the valve stem, so that the valve closes when you aren't pumping air into the tire.
Aug 19, 2017 | Bontrager Cycling
When shifting front derailer,it doesn't quite reach the next sprocket.
Two things you will need to check.
There are two stop screws, one to limit inside movement, and one to limit outside movement, this will need to be tuned. 20932402-rsx4m12fp5prszbjjw0ik22q-1-0.jpg
Some may even have a H (high big blade) and L (low - small blade) indications. Screwing them out, enables MORE freedom in that direction.
The last thing to check, is the cable that pull the deraileur, if you cannot reach the limits you need, it might have slipped on the cable, then you need to release it - on small gear, pull it out as far as you can, and tighten it again, and hold thumbs that it works!
Oct 23, 2013 | Giant Boulder Se Mountain Bike 19"...
My gallant wont crank unless I keep trying for a while the starter turns but wont engage
There are a lot of things this could be and it is hard to tell without hearing the noise it makes. It could be the starter is not throwing the bendix far enough out to reach the teeth on the fly wheel. It could be the flywheel has bad teeth or the starter has bad teeth.
Oct 02, 2013 | Mitsubishi Galant Cars & Trucks
When i load my disk, halo reach, it makes a clicking noise and then it scratches the disk. it hasnt happened with any other disk so far. why does it only do it to halo reach?
I had the same problem.
I knocked onto my 360 a few times, and the laser has gone back into position.
No weird sound, or disc reading errors since.
NOTE: Im not sure this is your problem, but its a thing you can try anyway :D
Jun 18, 2011 | Microsoft Xbox 360 Console
On opening the hot water tap the boiler fires up and lights but when it reaches 50 centigrade the light goes out and the water goes cold...why?
few things to check since you really dony say what you have far as brand model size age this all helps alot but things to check are thermocouple, limit switch,high pressure switch, exhaust draft motor
Sep 11, 2010 | Heating & Cooling
Refrigerator not cooling
If your freezer is freezing and the fridge is warm the duct is frozen over between them, so the cold air can't get in. Sears has been out to fix this 5 times, this thing is a piece of junk. Almoust all the parts have been changed so far and the same thing happends over and over again.
May 25, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
The grill hood open so far that i can not reach it
you could try drilling a small hole in the lid and the bottom casting and get a piece of chain to bolt into the holes and keep it as short as you would want the lid to open. hope this helps.
Oct 13, 2009 | Uniflame FG2204C Grill
Paper Jamming
The problem with your printer is likely to be dust getting the way of your sensors; preventing it from seeing paper, preventing the rollers from effectively feeding the paper. This is if you are sure all other things are in proper working condition. Just get a long reach brush and try to reach in as far as possible and brush as best as you could, front and back is there is access.
Sep 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cobra 25 LTD 40-Channels Base CB Radio Logo
307 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
