Question about Ricoh Aficio 1018D Copier
I have a savin 2515 and she doesn{t print and also cannot access to web image monitor, she print a sheet that shows tcp/ip disabled and i don{t know what to do, i conect the machine with crossover cable, tcp/ip on the pc and one more to the copier and nothing not even i can see it on a ping on ms dos. pleaseee i need help.. so urgent i have 3 copiers 2 (1 savin 2515 . 1 gestetner 1502 and ricoh 3224 who doesnt print either) if you can help me with this problem i would be mor happy than ever. thanks. r_ferrer_s@hotmail.com
SOURCE: Printing labels on Ricoh 1224C copier
Labels should only be printed through the bypass tray. when printing, go to "properties", "Paper" and change tray from "auto select" to "Bypass tray"
Posted on Feb 14, 2009
SOURCE: what is the sulution for e541 copier machine ricoh 5832
SC 541 indicates a problem with the heating unit thermistor in the machine.
This type of inquiry requires service support from your local authorized dealer or original point of purchase. This type of service code can not be reset by the user for safety reasons.
Posted on Feb 23, 2009
  • 92 Answers
SOURCE: Please help re: Xerox 2515 large format copier
the first step is to pull the paper out and see if the feed rollers have left a mark on the paper that would mean your rollers are turning just not picking up the paper if this is the case remove the paper tray and with a wet rag clean the feed rollers always easier with a flash light keep in mind they may need to be replaced call 7734748865 il b happy to help
Posted on Jun 26, 2009
Matt_Sr
  • 31 Answers
SOURCE: i need help on how to disable the functional code
Thats a fuser failure code. I suspect your upper roller is bad and has loaded up the temp sensor. The sc545 is dangerous to play around with, a possible fire danger has occured and the machine has locked you out. This requires a tech to inspect and reset. Ricoh does not allow qualified/certified technicians to disseminate this information out to the customers due to the dangers involved.
Posted on Jul 29, 2009
  • 143 Answers
SOURCE: i still need help on how to solve or fix my Ricoh
You can check the following.
1. hot roller thermistor is out of position or dirty.
2. Fuser lamp is broken.
3. Thermostat is open. (Like a thermal fuse, there SHOULD be continuity)
4. Clean and scrap clean the gold pins that connect into the copier. Sometimes they get corroded or bent slightly out of shape so they don't make contact with the terminals.
Posted on Aug 03, 2009
Double Sided Copies on Savin 2535
The image shows a flat page with a 1, arrows to an image of a sheet with the lower right corner turned up with a 2 on it. On a Ricoh, just remember that the first image is the input and the second is the output.
Feb 06, 2014 | Savin Office Equipment & Supplies
How can I print a configuration page from the E260dn Lexmark?
Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address
in the TCP/IP section.
Click Reports.
The following reports may be viewed from the Embedded Web Server:
Reports
Device Statistics
Device Settings
Device Information
Profiles List
Printer Server Setup Page
Jul 25, 2012 | Lexmark E260dn Laser Printer
Copies to light on my Xerox 5334. Adjusted to darkest setting, changed dry ink cartrige, tried standar and photo settings. what is the next thing to check??
Check the number of images the drum has printed. You can find this on the config sheet. If you use the CentreWare software, you can access the printer from your Internet Explorer web browser by typing the TCP/IP address in the address bar where the URL normally goes. Then access the status tab to check on consumables. If the drum is nearing its threshold 24K to 48K, it may be time to replace. If the number is lower, check the transfer roller for excess paper dust contamination. Cleaning this off with canned air will help usually.
Mar 05, 2010 | Office Equipment & Supplies
Savin 9945DPE cannot Network print
Did you format the new drive through the service mode on the copier? As long as the drive is compatible then it should work once you format it.
Jan 03, 2010 | Office Equipment & Supplies
I have a ricoh sp 3300dn and neet to set the ip for it, can anyone tell me how this is done, you can't do it for the printer like most. rick
Configuring DHCP/BOOTP
To enable or disable DHCP/BOOTP, use one of the following methods:
• Web Image Monitor SP 3300 Series: Select Network Settings >
TCP/IP and select DHCP or BOOTP from the IP Address Assignment
Method list.
Creating a Standard TCP/IP port
1 In Windows XP, click Start > Printers and Faxes.
In Windows 2000/Windows Server 2003, click Start > Settings >
Printers.
In Windows Vista, click Control Panel > Hardware and Sound >
Printers.
2 Click Add a printer or double-click Add printer, and then Next.
3 Click Local printer attached to this computer and then Next.
Make sure that Automatically detect and install my Plug and
Play printer. is not selected.
4 Click Create a new port, select Standard TCP/IP Port from the
Type of port list, and click Next.
5 Click Next.
6 Enter the IP address or DNS name of your network printer and click
Next.
For the port name, a default name will be entered by Windows. You
can change it to a more user-friendly name.
7 Follow the instructions on the screen to complete installation.
Now, you can select your printer from the Print Setup dialogue box.
reply if you need more
timothyvdh@gmail.com
Jul 30, 2009 | Office Equipment & Supplies
Ricoh 5510L Network Setup
Go to user tools-key op tools-network-tcp ip- ip address put the appropiate info in.(including gateway address.) then type the ip address into the top portion of a web browser an you should be in web image monitor. you configure the printer there. User name is admin no password. -Carl
Jul 07, 2009 | Ricoh FAX5000L Plain Paper Laser
Trying to install my computer to the copier printer
How about downloading the driver, connecting the machine to a tcp/ip port on your router, setting up an appropriate ip address, and subnet mask on the machine, then creating a new tcp/ip port in the 'add printer wizard' and use the machines ip address,and continue with installation.
Apr 01, 2009 | Office Equipment & Supplies
I HAVE AFICIO 2238C COPIER AND I WOULD LIKE TO EMAIL FROM IT. BUT I DON'T HAVE INSTRUCTIONS TO DO OS.
Open the web web browser, and the IP address of your machine in the address bar to access the "web image monitor", and enter "administrator mode"
user name: admin
Password: (blank)
Enter proper network, tcp/ip, and email settings.
Can prove to be tricky if your not familiar with this type of setup.
Feb 20, 2009 | Ricoh Office Equipment & Supplies
Lanier ld122 503 service unavailable
This can occur if the Web services has been turned off in either the Web Image Monitor or from a telnet command for this device.
To check the status of these services you will need to telnet into the device.
1. From a command prompt type : telnet then the IP Address of the device
2. Telnet will respond back with a request for a login and then a password. Enter the login and password. The login and password used for Telnet are the same credentials that are used to log into the device’s Web Image Monitor (WIM).
3. Type in show at the msh> command prompt.
This will output many lines of information. The information you are concerned with is under the TCP/IP-Mode heading. You may need to scroll up in the command prompt window to see these services. The device’s services will be shown followed by their status. The ‘show’ command will show if the services are enabled (UP) or Disabled (Down).
4. If Web shows a down status, at the command prompt msh> type in set web up.
5. At the command prompt msh> type in logout
6. To make your changes Active you must type yes when prompted to "save configuration data"
Note: Always check with your system administrator before making any changes on a network device.
Aug 19, 2008 | Ricoh Office Equipment & Supplies
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
128 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
