I need to know how to change the ink cartridge. how do i get it out of the printer?
    Brigadier General:
  • 10,406 Answers
Turn the printer on.
Lift the hinged cover to expose the print-heads.
Look inside that cover, to see if instructions are affixed there.
After a few seconds, the print-head will slide to a position where you can remove the ink-cartridge -- you may have to press "down" to "unlock" it from its normal position, and then it should slide out.
Or, there may be a piece of plastic covering the ink-cartridge.
Push on that to "unlock" it, and swivel it "up" to fully expose the ink-cartridge.
Posted on Sep 15, 2010
I dont know how to change the ink cartridge on my lexmark?
For more detailed instructions on how to change/replace the ink cartridges in your Lexmark printer, please refer to the Lexmark X5650 User's Guide. Turn to page 111 - Maintaining Print Cartridges.
I hope this information has been helpful.
Nov 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
I've never change the ink cartridge before.
Usually you can find that the top of the printer can be lifted open. You will then see the three ink cartridges. remove each cartridge and see how low the ink level is if there's a centimeter or more it should not need changing. However some brands will force you to replace them all. or it won't accept that you have followed the directions.
Good luck,
Jim Hart
Jun 20, 2010 | Epson Stylus NX400 InkJet Printer
Printer doesn't revognize new ink cartridge
Are you using Dell Series 5 ink cartridges? Dell Series 5 ink cartridges have a cartridge that cannot be reset.
Article on refilling Dell ink cartridges
It's possible to get a bad Dell Series 5 ink cartridge. Return to place of purchase for a replacement.
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HPofficejetpro L7580 doesnt recognize cartridges have been replac
hELLO THERE
there should be a section there for the maintenance of the cartridges and change cartridges make sure that you use this whenever you change out a cartridge cause if you use this when you change out the cartridge the printer will always show low on ink also you can reger to your users guide for further instructions on how to do this ok? hopethat this has been very helpfull dont forget to rate my solution
best regards mike
(USN) retired
Aug 05, 2009 | HP Deskjet 6940 InkJet Printer
How do i change ink cartridge 21 in hp deskjet D1460 printer
Here is the manual for your printer courtesy of HP:
http://h10032.www1.hp.com/ctg/Manual/c00905267.pdf
On page 47 of the manual it explains how to change out the cartridges.
Let me know if you need more help.
May 23, 2009 | HP DeskJet D1460 InkJet Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Need to know how to change ink cartridges, need manual
Both of your answers are at the below link.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=257&modelid=15600#DownloadDetailAct
hope this helps
Apr 13, 2009 | Canon iP3500 Photo Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
jasbo
jasbo
