Question about Gsci GS7 Goggles
Detection Range of GS-7
How far can it see?
    Scholar:
  • 38 Answers
It depends on the lighting conditions in the environment you're using them in. If you're in a field out in the country with no full moon, and only stars for ambient lighting... A Generation-2 set of goggles aren't going to see very far. But in the same spot with a full moon directly overhead you could theoretically see in excess of 800 yards.
That particular model has 3 different range settings for the Infrared Illuminator. Close, Medium, and Far. Although there doesn't seem to be any set value for the longest you can see, set by the manufacturer.
Posted on May 16, 2008
Why does my coffee maker Capresso Team GS leak water?
Hello, what I have found is the most common cause of water leaking out of the bottom of the capresso team coffee maker is a leaking silicone hose that runs to the boiler (See the photo below with the split in the hose). The replacement silicone hose needs to be safe for beverage dispensing, food & dairy processing, taste and odor-free, with a temperature range of -75? to 350? F. All you need is a sharp pick, a phillips screwdriver, and a pair of needle nose pliers. Remove the four rubber pads on the bottom using the pick. Use the screwdriver to remove the six screws holding the bottom plate on. Remove and replace "BOTH" hoses using the needlenose pliers to pinch the hose clamps. Better to play it safe while you have it apart. If one is bad the other is likely not far behind. I hope this helps. acccadfd-0d5d-4c31-b1b9-a56192db9bc2.jpg
May 09, 2014 | Jura Capresso CoffeeTEAM GS 46405
2003 lexus gs300 misfires only when cold
What have you checked so far ?
You need spark at the right time, fuel to the injector, and normal compression for the cylinder to produce power.
Could be a spark plug, injector, or several other things.
Feb 04, 2013 | 1998 Lexus Gs 300
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
Green light on control panel constenly blinks
This condition can also apply to a dishwasher that has had the electronic control replaced.
A heater fault detection program has been added to the
electronic control to check for temperature rise and shut
down the dishwasher if a temperature rise is not detected.
The cycles have been modified to add 8 minutes 45
seconds of fixed heat at the beginning of the main wash.
If the temperature rise is less than the criteria, then
the unit will drain and blink the clean light 7 times. The
detection will be ignored if the temperature is out of its
normal range, 64° - 160° F, or the door is opened during
the fixed heat.
Once a heater fault is detected and the condition resolved
the electronic control must be reset by initiating a service
diagnostic cycle.
Sep 17, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Default code P1451 Land Rover Discovery II
The code P1451 on a Land Rover is "Leakage Detection Module Motor power stage error Drive cycle A:Signal out of range - above maximum". This is an OBD-II diagnostic system code. As far as I know, a 1995 Land Rover Discovery does not use a OBD-II system. Is it possible that this rover is a later model year
Oct 11, 2009 | 1995 Land Rover Discovery
Emission leak code comes on replaced gas cap came on agian in acouple of months
the gs cap isnt the only reason for this...a cracked hose at the caniste or leak detection pump can cause it....a bad lek detection pump or canister is also a possibility
Aug 02, 2008 | 2004 Dodge Ram 1500
Detection range of metering
In Digital ESP metering and Center Weighted Averaging metering, the detection range is EV2 through EV20. In Spot metering it is EV3 through EV17 (50mm F2, equivalent to ISO100).
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Gsci GS7 Goggles Logo
80 people viewed this question
Top Gsci Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Gsci Optic Expert? Answer questions, earn points and help others
