Question about Kodak Cameras
How do you access the HDMI port? Is there a button or is there a way to slide or pop it open? It should be simple but I don't see s reference to it in the User Guide.
    Brigadier General:
  • 11,967 Answers
We need to know the model to be able to tell you where the HDMI port is.
Posted on Sep 15, 2010
How to Resolve No Sound on Windows Computer?
Ensure that you aren't muted. The Windows Sound icon is small, and it can be tough to see if you are muted or not. Click the Sound icon in the System Tray and then click the Speaker button in the pop-up that appears to toggle the mute
  • If you don't have a sound icon, then your sound drivers are likely not installed correctly.
Inspect the speaker or headphone connection to the computer. A bad connection is one of the most common causes of no sound, and is also one of the easiest to fix. Make sure that your speakers or headphones are plugged in completely, and that the cables and connectors aren't damaged.
Ensure that your speakers are connected to the right port. Make sure that your speakers are plugged into the correct port on the back of your computer. The green port is most commonly used for external speakers, while the orange and black ports are used for surround sound systems and subwoofers. The pink port is for microphones.
Make sure your speakers are powered and turned on. Many speakers require a power connection, and may need to be turned on in order to work. Check the volume controls on the speakers as well to make sure that they're turned up enough to hear.
Reconnect your HDMI cable. A common problem for HDMI users is that no sound comes out of the speakers that the HDMI cable is connected to. A simple fix for this is to unplug and then replug the HDMI cable, which should switch the default playback device to the HDMI device.
Oct 20, 2016 | Microsoft Computers & Internet
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
PDP 435HDG HDMI selection
Do a factory reset to this set and proceed. Refer its user manual for details.
Jun 05, 2012 | Pioneer Pdp-4360hd 43 Purevision...
47 7300 only one Hdmi port is working
just open the back cover to access the internal part of the tv unit. now re soldered the pin terminal port of the other HDMI port usually a cause is loose contact. after that if still doesn't recognized and not working fine the other port you will need a digital tester check open component resistor as will as shorted diode connected going to the pin terminal of the HDMI port so that the input signal will be recognized. replaced defective component with the same value. hope this will solved the problem thanks for consulting through fixya good bless.
Aug 15, 2011 | LG Televison & Video
Where is the HDMI port on a Sony Bravia KDF-46E3000
There are two HDMI (High Definition Multimedia Interface) ports on your Television.Please refer the diagram below to know about the HDMI ports of your Sony Bravia KDF-46E3000.In the diagram the labeled ports numbered 6 and 7 are the two HDMI ports on your television.You can connect your TV with other devices which supports HDMI with an HDMI cable to view High Defenition videos.
Hope you are satisfied with my solution.Thanks for choosing Fixya.Your valuable feedback would be appreciated.
Jul 23, 2011 | Sony Televison & Video
I PURCHASED A MAGNAVOX Z V 427MG9 A VHS DVD RECORDER.I HAVE A NEW VIZIO VW26L HDTV. HOW DO I CONNECT THEM? I HAVE ALREADY CONNECTED A HDMI CABLE TO IT BUT DON'T KNOW TO SET IT UP. DO I NEED ANY OTHER...
HDMI cables are actually wonderfully simple to connect. Once you have connected one end to the TV and one end to the DVD player, you will simply need to change your input channel using your TV's remote. Find a Input or Video source button and press it until the screen says HDMI. Now your TV may have several HDMI ports so you may have to try a couple HDMI channels before you find the right one.
Hope that helps!
Jul 19, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I can't get a signal from my desktop to my hdtv when I use the hdmi port. The desktop is a gateway GT5676
First, make sure the computer port is working in the computer by going to the device management ICON in control panel.
Once you check that, make sure you have set up your preferences in the TV to allow "INPUT" from the HDMI port. If you have more than one HDMI ports make sure you have the correct number listed. This is a common error. It would be the same if you are running a DVR with an HDMI cable, you need to set up the TV. Normally you hit the "INPUT" button on the remote control and a list pops up. Scroll over with the arrows to the correct HDMI port. You will likely need to do this again to get back to the cable input once you are finished with the computer connection.
Feb 10, 2011 | Gateway GT5676 Desktop PC
I cannot stick a hdmi chord in the hdmi port it is blocked and cannot not be open by hand how do I open it
Your computer may not actually have an HDMI port. The spot you are referring to is most likely where to manufacturer puts an HDMI output for higher model laptops.
Jan 13, 2010 | Toshiba Satellite A100-S8111TD Notebook
Have a Toshiba 42hm66 tv. The HDMI port has quit
The best thing to do is to call Toshiba at 1800-631-3811 and see if they could refer a Service Facility to you to check it out. I would guess that that Board that has the HDMI Port on it needs to be replaced but it is not a easy or simple job.
I hope this helps,
Skyassoc
Sep 17, 2009 | Toshiba 42HM66 42" Projection HDTV
Cameras Logo
18 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
