Question about Electrolux Epic 6500 Vacuum
WE NEED A NEW FILTER FOR EPIC 6500 mODEL # c102g
  • 694 Answers
Filter can be purchased at or ordered from your nearest Aerus franchise. For store location, see below site and enter zip code.
http://www.aerushome.com/storelocator/
Posted on Sep 24, 2010
I need a operating manual for EPIC 6500 Model 1763
You can download the manual from the Aerus/Electrolux site.
http://www.aerushome.com/Site/Manuals
I hope this isn't too late.
Jan 15, 2016 | Electrolux Vacuums
Why does it start, then immediately stop and bag light comes on?
My epic 6500 starts for a few seconds and turns off. With the filter light on. I take out the filter and it still does it. It only stays on if I cover the filter hole with my hand. Any solutions.
Oct 23, 2015 | Electrolux Epic 6500 Vacuum
Accessory compatibility between Electrolux Models 1521 and Epic 6500 SR
No, they have different connectors. 1521 uses a pigtail hose that has little metal clips. 6500 has a plastic end with an arrow that helps guide you for proper placement. Unfortunately you will need 2 separate hoses for the respective models.
May 12, 2015 | Electrolux Vacuums
I just purchased an Electrolux Epic 6500 SR, Model #C102G. I found that inside the cover over the bag. But where is the Serial number? I can't seem to locate that anywhere. Also, in case it breaks, I will...
The serial number is on the bottom of the machine. I believe near the front wheels, but can't remember for sure.
Parts can be purchased at any authorized Aerus Electrolux store. You can locate the one nearest you using the below link.
And you can find a manual for it using this next one.
http://www.aerusvacuums.com/support/manuals/
Mar 03, 2011 | Electrolux Vacuums
We have an Electrolux 6500 SR Model C102G. We
yes it wears out it is a common problem i eliminated several of them for people its a job that takes alot of patience i opt to just eliminate the part its sort of useless and causes your machine to act contrary if you want to replace the part here is the place Electrolux Aerus 4526 Maccorkle Avenue
South Charleston, WV 25309-1409
(304) 768-2158.. if you cant fix it contact me and i will repair it for $35.00 plus parts or no parts either way it can be fixed the above contact is the dealer i use for parts
Jun 13, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
How do I get to the filter on my epic 6500?
you have a bad controll valve inside the tank. take it to vacuum shop, they can fi the problem and sell you replacement filters. your filter under where the duster brush is stored on top.
Jun 26, 2009 | Electrolux Epic 6500 Vacuum
I need a service manual Electrolux 6500
I don't have a service manual but maybe I can give you some instructions that will make some sense. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. I hope this helps. Good Luck!!
Jan 01, 2009 | Electrolux Epic 6500 Vacuum
Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
Apr 01, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
85 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
