Question about Kenmore 24 in. 17032 Built-in Dishwasher
Machine will not cycle. No button will start machine. We replaced the control board as advised by repairman, and it is doing same thing
  • 901 Answers
Check for any other circuit board!
Posted on Sep 15, 2010
Problem accepting commands
must have never been in the army, huh? just kidding..
so this is or is not working on some cycles..can you clarify this?
Oct 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
Since that you let repairman do twice and didn't fixed the problem, I think your washer have still warranty from the vendor. and they repair it free.
Please verify the panel board of the machine maybe got grounded in the wiring or got wet. How ever you can do that in your own you should consult the repairman on that matter. however the two repairman did not resolve, so its better to bring the washer's to the vendor. im sure they can fix the issue or you will be enlightened by their valuable suggestion and solution.
may this help
melnavz
Oct 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
My washing machine will lock the door, start the cycle and within a minute, it will start beeping and flash an F, then an 11. At this point, I will hit the cancel button to break the cycle. Sometimes,...
The F11 error code is a communication failure between the 2 control boards. This includes both boards & the wiring harness as potential defective components. However, this is usually the main machine control board that needs replaced.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My LG steam washer won't finish a cycle. It is getting stuck on the rinse/spin part of the cycle.
Turn the machine to on and do not pick a setting such as towels normal etc, instead just choose the no spin option on the control panel and press the start button. The cycle will last one minute. Do this to drain any water that has accumulated. You may need to decrease your load to 1/2 (I know it's ridiculous) and use less detergent (again I know) . See what happens. Your machine may be off kilter as well. Due to that fact that they have sensor mechanisms, any little thing throws it off. If none of the above works, call customer service if your machine is under 1 year you are still under warranty. If not, call a local repairman (Sears should have a list).
Nov 04, 2010 | Washing Machines
Washer stops mid cycle!
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Same problem
This machine has a circuit board with some models having a known defective board, which GE is replacing free of charge.
Check with GE to see if you qualify.
Along with the board there are usually 5 thermistors that control the operation of this machine, along with many other controls.
My personal opinion is this machine is radically over-engineered
for a device that is designed to freeze food and keep milk cold.
I recommend calling GE factory service to correct the problem.
If their service does not solve the problem(s), then call them back until they do. Most states have a law that is called something like reasonable expectations. It is a law that states, irregardless of the printed warranty period, the machine should provide reasonable service that a normal person would expect when purchasing any
machine.
Aug 22, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
F1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Mar 21, 2009 | Kenmore Washing Machines
Washing machine suddenly stopped working during cycle
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 01, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Whirlpool Duet Model GEW9200LW1 Dryer
William, start with the simple things first. Make sure the control is not locked by pressing and holding the end of cycle signal for 3 seconds. This will lock and unlock the controls. If that is in order the next step would be the door switch. By pressing in this order: more time, less time, more time, less time you will enter the diag mode and all the lights should light up. Open the door and you should hear a beep and see a code, such as OE,1E,2E etc. If no beep is heard you could have an issue here. You can also check this at the board. You have to remove the top cover by removing the 3 screws in back. Slide the top off toward the back. The board is on the left. With the power disconnected ohm out P1-2 (white wire) and P1-3 (blue wire). With the door closed you should read continuity. Start with this first and post back...Catriver.
May 06, 2007 | Whirlpool LAB2700ML Pedestal Drawer for...
Kenmore 24 in. 17032 Built-in Dishwasher Logo
66 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
