Power - Solid
DSL - Solid
Internet - Solid or flashing quickly when data is being transferred.
Ethernet - Only on and flashing quickly if cable attached to it and an active device
Wifi - Solid or flashing with active data transfer
see that top hose. on RAD, follow that to mr. stat housing
there are exections,
cross flow rad, or reverse flow rads.
but there is only 2 hoses there, id bet a 1second glance
shows you where it is. right? 2 huge hoses.
do u have dynamic ip or static ip if u have any fix ip so fix in the network property proper way check your dns if the recived dara not up so complaint your ISP
leak in the compession /broken cilinder head to cooling (compresion )/thermostad thad regular the teperatuur radiator not clean insite corrosie from cooling liquid
