Formatting HDD I would like to format the C drive of my hard disk. The OS (MS XP Pro) files are in this drive. How do I go about formatting my hard disk???? I have the Windows XP installation cd with me. Thanking you Deepak
  • deepak_a May 18, 2008
    At present the OS is installed in the C drive.
    Is it possible for me to load the OS in the D drive also and then format the C drive???
  • deepak_a May 21, 2008
    If i install MS XP in the D drive also, then when the computer boots up how do i know which XP is running, I mean how do i know whether the XP os installed in C drive is running or XP os installed in D drive is running???
    Is there a way i can select from which drive to run the os???
    Genius:
  • 2,785 Answers
Just go to bios and make the first boot device as cd rom then you save and exit, insert you installation cd in the rom and follow the instruction,
Posted on May 16, 2008
  • 1 more comment
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 17, 2008
    you cant format the c drive if the operating system is load in that drive you have to follow the above solution,if the os is not loaded then just go to mycomputer and right click and click on manage then click on disk management then right click on c drive and click on format
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 19, 2008
    yes you can
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 21, 2008
    you shoud get the option after the bios screen
Adding 250gbhd to double my storage.Hdd in bios but not in "my computer"
Is this an internal or external drive? If it is an internal drive, you need to partition and format the drive. For Windows XP and later, this is available in the drive management service. In Windows 7, click Start > Control Panel > System and Security. Look in Administrative Tools and click on Create and Format Hard Disk Partitions. (Make sure that you have logged in as the administrator.) In the lower section of the window, the new hard drive should show (probably as Disk 1). Select the correct drive (it will probably say unallocated space). Click on Action > All Tasks to find the option to format the disc. If this drive will be used with the current computer or only with the recent Windows OS, format the disc in NTFS. Mac's have a similar utility but HFS is their current file system. If the drive will be used on multiple computers with different OS versions, format it in FAT32.
Other programs (Partition Magic, Partition Manager) will give you more options for formatting.
If this is an external drive, looking for the drive in Disk Management will let you check if the OS finds the disc but has a problem with the format.
I hope this helps.
Jun 07, 2012 | Computers & Internet
My laptop lenovo ideapad y450 shows blue screen error.i tried to format with windows xp also,but it appears once format was completed also.advice me pls
Dear! Delete your C drive and create again with the help of windows and then format and install Windows. Your problem will be fixed.
Jul 27, 2011 | Computers & Internet
I don't know how to select the type of partition needed for my mac when I am formatting the drive for mac OS?
1 - Place the drive on the desktop.
2 - Start the "Disk Utility." Click on the drive, then on the "Erase" button.
3 - Select the "MS-DOS File System" in "Volume Format."
4 - Provide a new name for the drive. Click the "Erase" button.
5 - Perform the instructions given on the screen and finish the formatting.
Apr 02, 2011 | Bernoulli Iomega Prestige Portable hard...
I bought a StoreJet 25M 640 external hard drive. When i try to use it with my MacBook Pro I am told I have to reformat the HDD. Is this right? How do I do this?
It is dependent on whether you are solely going to use the Hard drive with your macbook or whether you may use it on a PC as well. If you are going to use it with just the mac format it in Mac format if with PC and Mac format it for a PC.
You format the drive using disk utility which can be found by opeing up the applications folder and then the utilities folder. Open up disk utility and then on the left hand side select your hard drive, then select erase from the right. For Mac formatting under Volume Format select "Mac OS Extended (Journaled)" then name the drive and then click "Erase..." For PC formatting under the Volume Format select "MS-DOS (Fat)" Remember reformatting will wipe any information from the drive.
Hope this helps.
Dec 15, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
I need to format an HDD for an IBM thinkpad 570e that came without one, and from what a lot of people say, it won't take windows xp pro. I don't have any other OS, so has anyone tried to do this...
Before formatting the drive ....
you will need to save your drivers on a cd/dvd disk if you dont have the original disks
Formatting the drive should be straight forward,
remove it from your machine and take it to another computer,
your IBM Thinkpad should be staight forward to reinstall even without taking your drive to another computer,I found this step easier tho....
after formatting this drive you could just insert to your machine and then reload your software from the beginning providing you have your disks,
You might have a password locked hard drive and or your bios may be locked also ,in this case replace the drive after which your new os install should give you access and functionality,
update your drivers on the internet and SP2 updates will give you hi speed usb 2.0 functionalilty.....
Good luck with the formatting,if you need help let me know,
have a great day
MISTERDJ
Sep 06, 2009 | IBM ThinkPad 570E Notebook
Copying Files to PS3
Check what the "File System" type is by going to Start, Control Panel, Administrative Tools, Computer Management, Disk Manager. Select the external drive and read the "File System" type. The file system type must be "FAT32" in order for the Playstation to recognize it.
  • If the file system type is "NTFS", right click and select "Delete Partition" or "Delete Volume" for Vista.
  • then recreate the partition but do NOT format it. Make sure you assign a drive letter (for this Tutorial, we'll use h:)
  • If you are running Windows, format the drive by going to the command prompt (Vista, right click on command prompt in start menu and click "run as administrator")and type in "format h: /FS:FAT32" (without the quotes). You may need to substitute your drive letter. (note this will not work on XP for a large hard drive - you will have to use a third party formatting utility)
  • If you are using Mac OS X, open /Applications/Utilities/Disk Utility.app, pick the drive, and click on the 'Erase' tab. Pick 'MS-DOS (FAT)' for the file system type, and click on the 'Erase' button. This will reformat the drive in FAT-32.
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
I'm new to building pcs and this is my first build. I have two Seagate Barracuda 7200.10 ST3250310AS 250G hdd's installed in my newly built pc. I have yet to detect a driver when trying to install ...
There are many ways to format your hard drive but i will tell the two ways.
  1. while you installing the os like windows xp,2000 it ask you to format the hard disk to install the windows operating system. It comes before the copying the files into the hard disk while you install the windows.
  2. Another way is formatting the harddisk is by seagate software like DM (Disk Manger) is comes with the harddrive or you can download the software from the seagate website for free. DM is the software for formatting . so you can format your harddrive by these software.
May 03, 2008 | Computers & Internet
One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Feb 08, 2008 | Computers & Internet
HDD wont get formatted
Hi, maybe the easiest way for you to format this drive would be if you could attach it as a secondary drive in a pc that is currently working and then try formatting it in the desired format from within windows. Windows will recognize a drive it only needs to format it in order to access it for data storage. You may need to change the jumper setting to slave on the HDD before you plug it in.
If you need any help with this just let me know.
SeaJade
Jan 26, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
