Question about Gateway LX6820-01 Desktop PC
Front panel wiaring diagramme for acer g43-t am motherboard with 13 pins i need help connecting the pins
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
How to connect front panel to acer power s290 motherboard
http://www.ascendtech.us/acer-aspire-sa90-mbs7109002-motherboard_i_mbacembs7109002.aspx
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Looking at the Front Panel header it is parallel to the outside edge on the bottom/right of the motherboard.
13 pin header.
6 across the Top row with 1 pin missing, 7 across the Bottom row.
Top row is numbered EVEN
Starting on LEFT side coming across to the Right, Top row;
Pins 2, 4, 6, 8, No Pin, 12, and 14.
Pins 2 and 4 have a Green area
Pins 6 and 8 have a Red area
No Pin 10.
Pins 12, and 14 have a Yellow area
Bottom row is numbered ODD.
Starting on LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
No Pin 10.
Pins 12 and 14 have a Green area.
A) Pins 2 and 4 in the Green area (Top left) are for the Power On LED
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 in the Red area are for the Power On switch.
C) Pins 12 and 14 are N/C. Not Connected
D) Pins 1 and 3 in the Yellow area, are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
E) Pins 5 and 7 in the Purple area, are for a Reset switch, IF a Reset switch is used.
F) Pins 9, 11, and 13 are N/C.
(Pin 9 is 5 Volts DC. Used by the factory for testing)
Regards,
joecoolvette
(I thought the internal speaker was that round little 'buzzer', below the bottom white PCI slot, (PCI 2), and close to the edge of the motherboard )
Nov 01, 2012 | Acer Power S290 PC Desktop
Motherboard diagram Acer eMachine MB DA061/078L
Hello? Tap, tap on the monitor. What are you reading from?
http://www.ebay.com/itm/Acer-MB-NB107-001-DA061-078L-Motherboard-eMachines-08120-2-780G-AM2-Desktop-/280919767281?pt=Motherboards&hash=item41681f78f1
The area of contact pins on the motherboard, that the main wires go to from the Front panel, is the Front panel header.
Motherboard installed in computer, the Front panel header is at the Bottom/Right.
Two rows of 7 pins in a small black rectangular plastic block.
http://www.ebay.com/itm/Acer-DA061-078L-Motherboard-eMachines-EL1200-X1200-AMD-780G-Socket-AM2-DDR2-/140825131784?pt=Motherboards&hash=item20c9d4fb08
TOP row of pins is numbered EVEN.
BOTTOM row of pins is numbered ODD.
Starting on the LEFT side going towards the Right, TOP row:
Pins 2, 4, 6, 8, (NO 10), 12, and 14. Again, there is NO Pin 10.
Starting on the LEFT side going towards the Right, BOTTOM row;
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
2) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
3) Pins 2 and 4 are for the Power On LED (Light)
If the PWR LED is dim when the computer is on, switch the wires around.
4) Pins 6 and 8 are for the Power On switch.
5) The rest of the pins are N/C. Not Connected.
Don't forget to plug the 4-pin ATX +12 Volt power cable in,
(Top left corner),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 06, 2012 | Computers & Internet
Need diagram for connection on motherboard 4006272r
Gateway 4006272R motherboard;
Foxconn (Bengal) RS780 motherboard.
[ In otherwords the motherboard chipset is an AMD RS780 series,
http://en.wikipedia.org/wiki/AMD_700_chipset_series#780G.2F780V
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Radeon_R600_series
Scroll down to the bold black subheading - IGP (HD 3xxx, HD 4xxx ]
This motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the list click on -> Product Views
Now click on -> S - Front Panel Connector
Motherboard installed in the computer case, the Front panel header is at the Bottom/Right corner.
It has -> F_PANEL <- silkscreened in white underneath it.
Two rows of pins.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side, coming across to the Right;
Top row;
Pins 2, 4, 6, 8, No pin, 12, and 14.
Bottom row;
Pins 11, 12, 13, and 14 are NOT USED.
These pins are in the Orange blocks.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
These pins are in the Blue blocks.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
Black block.
D) Pins 2 and 4 are for the Power On LED. (Light)
If the PWR ON LED is dim when the computer is on, switch the wires around.
These pins are in the Green block.
E) Pins 6 and 8 are for the Power On switch.
These pins are in the Red block.
F) There is NO Pin 10.
Black block.
Again, Pins 11, 12, 13, and 14 are Not Used.
B- CPU Power Connector is at the upper left corner of the motherboard. This power cable is power for the Processor.
MUST be plugged in.
A general example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
Note the Lock on the side of the power cable's connector, and matching Lock Tab on the motherboard connector.
F- Main Power Connector also has a Lock, and Lock Tab.
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
D - CPU Fan Connector is above the processor socket, and near the top outside edge of the motherboard. ONLY plugs in one way.
Regards,
joecoolvette
Aug 10, 2012 | Gateway Computers & Internet
Where to connect the start switch
For the Abit AB9 pro motherboard?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127004
A) Motherboard installed in the computer case;
Processor to the Top, Ram Memory slots to the Right, white long PCI slots at the bottom;
The Front Panel header on the motherboard, is at the Bottom/Right corner.
[The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header ]
The Front Panel header is a plastic rectangular block, with TWO rows of pins.
20 pins. 10 on the Top row; 10 on the Bottom row.
TOP row; starting at the LEFT side going towards the RIGHT;
Pins 2, 4, 6, 8, No pin 10, No pin 12, No pin 14, 16, No pin, 20.
{4 pins, blank space where 3 pins would be, 1 pin, blank space, 1 pin }
BOTTOM row; starting at the Left side going towards the Right;
Pins 1, 3, 7, and 9. No pin, 13, 15, 17, and 19.
( Top row: 2,4, 6, 8, X, X, X, 16, X, 20
Bottom; ..1, 3, 5, 7, 9, X, 13, 15, 17, 19
X = No pin, or blank spot )
A) Pins 1 and 3 are for the HarDDrive activity LED light.
If the HDD LED is dim when the harddrive is active, and in use, switch the wires around.
(reset button)
C) Pin 9 is N/C. Not connected. (It was for factory use)
D) Pins 13, 15, 17, and 19, are for a Speaker. The small speaker is used so you can hear BIOS Beep Codes. The computers way of telling you something is wrong, and an area to look into for it.
Pin 13 is for the Positive ( + ) wire
Pin 19 is for the Negative ( - ) wire
E) Pins 2 and 4 are for a Suspend Power On LED light.
Ignore.
F) Pins 6 and 8 are for the Power On switch.
G) Pins 16 and 18 are for the Power On LED light.
Pin 16 is for the Positive ( + ) wire.
If the Power On LED light is dim when the computer is on, switch the wires around.
Motherboard manual. It is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click it may take up to 30 seconds, before the first page comes up.
Page 15.
http://static.tigerdirect.com/pdf/Abit_ab9_series_Manual.pdf
Regards,
joecoolvette
Jul 21, 2012 | Abit AB9 Pro Motherboard
WANT TO SEE DIAGRAMS OF A T650-8B7H ASPIRE COMPUTER COMPONENTS ie the inside parts motherbody ,power suply,processor,hard drive and sound and video cards
This is a PDF Service Manual for the Acer Aspire T650 series desktop computers, from Acer Support,
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS650_E500APF5_BOOK.book.pdf
After you click on the link you won't see anything happening for up to 30 seconds. The file is downloading in the background.
If you see the first page, and the file is still downloading, let the file download all the way before looking though it.
(Should the Service manual link not work for you, state so in a Comment)
Proper computer speak for motherboard is Mainboard. The mainboard is shown on Page 15.
Connections to the Headers on the motherboard, are shown on Page 19.
Orienting the motherboard so the Processor is to the top, and Ram Memory slots to the right, the Front Panel header is on the bottom right of the motherboard.
PANEL 1.
The Front Panel header, is where the various cables from the Front Panel of the computer go.
(Front Panel being the plastic panel in the front of the computer. For this computer, the Power On button, two USB ports, Speaker/Headphone jack, and Microphone jack are in the front panel)
To the left, and down a little bit, of the processor socket is the 4-pin ATX +12 Volt header.
Square in shape, white in color, 4 socket holes.
This is where the 4-pin ATX +12 Volt power cable plugs into. (Two Black wires, two Yellow wires)
This is power for the Processor. If it isn't hooked up, the Processor won't turn on. No power.
Below the Processor socket's left corner is the header for the System Fan. The computer case fan. You will see there are 4 pins.
One for 12 Volts.
One for Ground.
One for detecting the RPM's of the fan. (Revolutions Per Minute)
One for varying the RPM's of the fan. This is the sensor connection.
To the upper right of the motherboard is another small white header. (Connector) This one has 3 pins. This is where the Processor (CPU) fan plugs in.
The long white connector below the CPU fan header is a 24-pin ATX main power connector.
The 24-pin ATX main power cable plugs in here.
The Front Panel header, or PANEL 1, is on the very bottom right.
Has two rows of pins.
Starting from the left side going right, there are 4 pins, NO pin, then 3 pins on the Top row.
Starting from the left going right, there are 7 pins across the bottom.
The pins on the Bottom are numbered Odd.
Starting from the left going right, the pins are numbered,
1, 3, 5, 7, 9, and 13.
The pins on the Top are numbered Even.
Starting at the left going right the pins are numbered,
2, 4, 6, 8, NO pin, 12, and 14.
1) Pins 2 and 4 are for the MSG LED
(Pin 2 is for the + positive connection)
2) Pins 1 and 3 are for the HarDDrive activity LED
(Pin 1 is for the + positive connection)
3) Pins 5 and 7 are for the Reset switch. (Button)
(Pin 7 is for the + positive connection)
(Pin 6 is the + positive connection)
5) Pins 11 and 13 are for the ODD LED
(Pin 11 is the + positive connection)
6) Pins 12 and 14 are for the LAN LED
Page 116 shows an exploded diagram of the inside, of the T650.
Acer doesn't give info as to who made the motherboard for them. (All pre-built computers have their parts made by someone else)
Due to it's square shape it's a Micro-ATX form factor motherboard.
9.6 inches by 9.6 inches, or 244mm by 244mm.
(The Micro-ATX form factor can be as small as 171mm by 171mm.
The following will give you more information,
http://en.wikipedia.org/wiki/Motherboard_form_factor )
Information about the Aspire T650 motherboard from me,
1) Motherboard chipset:
The motherboard chipset, is what determines what components are supported on a motherboard.
(Chip and Chipset are slang terms for I.C. Integrated Circuit)
The motherboard chipset is the Northbridge and Southbridge chip.
The Northbridge chip determines what Processors, and Ram Memory are supported, as well as what High Speed graphics are supported.
(The Northbridge chip handles the faster processes of the computer.
AGP and PCI Express are high speed graphics.
Any graphics card inserted into a PCI slot, is low speed graphics. This is handled by the Southbridge chip. It's a slower process. Integrated graphics are also handled by the Southbridge chip.
You may wish to view this motherboard diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
CPU stands for Central Processing Unit, or for short - Processor)
The Aspire T650 motherboard has an LA 775 processor socket.
The Northbridge chip is an ATI RC410
The Southbridge chip is a ULI M1573
Underneath the processor socket is the Northbridge chip. It's sitting diagonally, and has an aluminum heatsink sitting on top of it.
Below the Northbridge chip is a PCI-Express x16 slot used for a graphics card.
Below the PCI Express x16 slot is a PCI Express x1 slot. White in color, much shorter than a PCI slot.
There are two white PCI slots below the PCI Express x1 slot.
To the right of these white PCI slots is the Southbridge chip. ULI M1573
To the right of this chip are 4 SATA headers.
Below the 4 SATA headers is the Front Panel header.
(PANEL 1)
Are you having problems connecting components?
Do you need to know what components you can upgrade to?
(Processor, Ram Memory, graphics card, power supply, etc)
If so, simply state what information you need in a Comment.
May 03, 2010 | AcerPower FE PC Desktop
Manual
I would like you to go here to Motherboards.org,
http://www.motherboards.org/mobot/manuals/MSI/MS-5185/
Where it states -> File: 5185v10.zipVersion:--Release Date:-- Download
I would like you to click on Download.
You will see a small window come up. Click on the empty circle to the left of -> Save
Unless, you have your downloads going to your My Documents folder (Start>My Documents) this will wind up on your desktop screen. It will be a yellow folder icon with probably -> 5185v10.zip <- under it.
Double-click on the yellow folder icon. You will see 6 PDF files.
5185-1.pdf, 5185-2.pdf, and so on.
To open them and look at them, you double-click on each one, one at a time.
Then in the File Download window, you click on Open.
In 5185-2.pdf, it shows you the Front Panel header, and where the Front Panel wires go.
(Not trying to insult your intelligence. The Front Panel is where your Power On button is. The Front Panel header is on the motherboard. A connector on a motherboard, is referred to as a Header)
Should somehow you can't download this PDF Motherboard Manual, I will try to explain the connections on the Front Panel header. Bear with me.
Viewing the motherboard with the processor up at the top, ram memory to the right, the Front Panel header is on the bottom right. It is the JFP2 header.
(The motherboard manual, clearly shows this header as being the JFP2 header. Then it states it's the JFP1 header. Believe there was a misprint. You'll know)
It is situated lengthwise up and down, parallel to the right side of the motherboard, with two rows of pins.
The pins are numbered 1 through 20. There are spots where there are No pins. Where there is no pin, I will state -> No connect
Starting at the top on the left side, and coming down.
Pin 18, 17, 16, 15, 14, 13, 12, No connect, and 10.
Starting on the top right side, and coming down.
No connect, 8, 7, 6, 5, 4, No connect, 2, and 1.
1.Pins 18 and 17 are for the Reset Switch
2.Pins 16 through 13 are for the internal speaker
3.Pins 12 and 3 are for the HarDDrive activity LED.
4.Pins 10 and 1 are for the Keylock Switch
5.Pins 8 and 7 are for the Power On switch
6.Pins 6, 5, and 4, are for the Power LED
Pin 6 is the Positive connection, (+)
This motherboard uses an ATX 20-pin motherboard power connector.
It is at the top of the motherboard, and goes across lengthwise.
There are 20 socket holes.
Pin 1 is on the top left. It uses an Orange wire. (3.3 volts)
Pin 10 is all the way to the right. It uses a Yellow wire, (12 volts)
May 10, 2009 | Intel Motherboard
Simple pinout help
Front Panel Header pin assignments as follows:
Pins 2 + 4 = Power Led
Pins 6 + 8 = Power Switch
Pins 12 + 14 = LAN Activity Led
Pins 1 + 3 = HDD Led
Pins 5 + 7 = Reset Switch
Pin 9 = +5v
Pins 11 + 13 = ODD Led
Pin formation is as below with no pin in position 10.
2 4 6 8 10 12 14
1 3 5 7 9 11 13
You will probably need to extend the Front Panel connector cable to reach the header pins on a replacement motherboard - I did this with 2 x N76HL 10 pin extension cables (male to female) from Maplin.
Mar 26, 2009 | Computers & Internet
Acer m464 front panel connectors
Sorry in the 1st instance for my lack of specific knowledge when it comes to ACER hardware.
Is the model of your MOTHERBOARD - Acer m464?
If so do you happen to still have a manual that came with the motherboard?
Sometimes you can see the pinout in white writing on the mainboard itself near the connector block... have a close look and see if it is there.
The pin out for the connector block will definately be in the mainboard manual. If you don't have the manual then you'll need to do a little searching for it... I'm sure a .pdf of it will be floating around... i guess start at the ACER site.
On the rack mount chassis, are the plastic chassis connectors grouped (ie. 2 wires into 1 connecter for pwr led, etc) or are they individual single pin connectors?
Either way for each group, one should have a little TRIANGLE on the opposing side to the writing. Conventionally this is your positive (+) pin when looking at the pinout diagram. Ensure you have correct polarity for all ur connections obviously.
See how you go mate.
Mar 25, 2009 | Acer Computers & Internet
Gateway LX6820-01 Desktop PC Logo
402 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
