Question about GE PFSS5NFY (251 cu ft) Bottom Freezer Commercial French Door Refrigerator
Does anyone have the GE Profile refrigerator #PFSS5NFZSS?
the dr
  • 447 Answers
SOURCE: TFX24PRXBWW GE Profile Refrigerator - energy use?
I dont know how to locate these specs for you, modern refrigerators are much more efficient for a couple of reasons. Most new units have a Computer that controls the defrost cycle whereas older units have timers that defrost every 8 hours of on comp run time regardless of whether it needs defrosting. The new ADC (adaptive defrost control) can better monitor the frost on the coils to defrost less (in the defrost cycle it consumes 5x as many watts as when its cooling. Also most new refrigs, especially new GE units have much more efficient fan motors now also, however they too are computer controlled and when they fail they are expensive. Also the very high end new Counter depth models (in the $2500+ range) have a new variable speed compressor. This gives the compressor the ability to run at a low, med, and high speed, reducing even more the watts that will be drawn in normal operation when the fan motors are on low and the compressor too. If you have any other questions let me know ill be glad to advise.
P.S. Buy an extended warranty with any new appliance you purchase! Trust me!
Posted on Dec 05, 2007
  • 531 Answers
SOURCE: GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
Posted on Apr 01, 2009
taran_2005
  • 10515 Answers
SOURCE: GE Profile Refrigerator model #TXP24PRYE with yellowed handles
Spray with clorox all purpose cleaner and scrub it with hot or warm damp wash cloth.If the handles are plastic, Krylon makes an excellent line of spray paint products that bonds to plastic and adheres to the surface. Most spray paint products only coat the plastic and on a surface like a handle that will be used constantly, is easily scratched or peeled. The Krylon plastic paint bonds to the plastic surface and is very durable. The one down side is if you paint the handles and don't like the results, there is no going backwards, you can't remove the paint once it has cured.
Thanks.
Posted on Jun 19, 2009
  • 306 Answers
SOURCE: GE profile bottom freezer refrigerator clicking
Your relay on the compressor is bad. It is called a PTC relay they are known to go out.
First be sure to unplug frig. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jul 05, 2009
  • 27 Answers
SOURCE: I have a ge profile side by side refrigerator.
First thing...Take a good look at all the door seals. If they let air and a lot of moisture in, that can condense and freeze causing your problem.
Second...Manualy defrost your freezer and see if the problem re-occurs. It may be that someone left the door open once and caused the icing.
Posted on Jul 18, 2009
Stopped cooling
more info needed, does the compressor turn on, if not thermostat or compressor issue. if it does turn on it can be that the evap is frozen. check with GE site to find out how to reset the controlling board.. normally its as easy as set to off and unplug for 10 minutes.but before using again you must thaw the evap completly,,w/,blow dryer and remove back wall on the inside of the freezer to expose the evap coils
Apr 06, 2014 | GE PFSS5NFZSS 25.1 cu. ft. French Door...
Not cooling
need more info is the compressor kicking in? is the light still working? is the fans still working? is it digital display and if so is that working?
GE profile refrigerator control board #
What is the model number of the unit?
Nov 11, 2012 | GE Refrigerators
Door Doesn't close on GE Profile PDS20SCRALSS
Check for long items, too big to fit in the fridge.
May 04, 2017 | GE Profile PDS20SBSRSS 30" 19.5 Cu. Ft....
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 24, 2010 | GE Profile TPX24PBDCC Side by Side...
GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
My GE refrigerator is not working
in the refrigeration section there is a fan assy and damper assy, theis assy is really one kit and needs to be replaced.
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Mar 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker doesn't make enough ice
Try turning the thermostat all the way down if it works you can back it down.
Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
GE PFSS5NFY (251 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
79 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
