Question about Compaq Presario M2000 Notebook
Two vertical lines on my compaq presario (M2000) laptop
I ma using compaq presario m2000 from last 3 years. but last month suddenly two vertical lines came on screen. lines are only 1px in width but one is of pink color and one is white color. The lines disappear when screen saver come. I am very much tried to seeing that . any one plzz help me to figure this out.
  • techies May 19, 2008
    Thanks ErikO
    for you fast reply. for your information line disapear only if the screen saver is of balck color. otherwise lines are still there on screen.
  • 37 Answers
Well, since the line disappear when the screen saver comes on, I"m led to believe that all the hardware side of the equation is OK. To put it simply, if there was a malfunction in the video (chances are) it would affect that too.
I would update (most likely available as nobody usually does this) the firmware for your video card. So identify the card EXACTLY, from documentation, or from the build list on the manuf. website, goto the manufacturer, say, ATI, and find the firmware there, where you will also find instructions to install it.
Then, just to be sure, I would update the video driver for Windows, in a similar manner to the instructions above.
If, despite all the above you still have a problem, then its time to get the computer serviced.
Good luck,
Posted on May 16, 2008
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
Hello! I've been using my Compaq Presario (2200) Laptop for 5 years now, then all of a sudden I saw 2 vertical lines on the screen. both the lines are clear red line , one located about 1/3 from the...
its the lifetime getting over of the lcd display , either get it replaced or just ignore it . Nothing of repairment can be applied to it . I am an authorised repairer for Compaq at my region . Sorry that we coudnt help you sir ,
Thankyou , please vote for me .
Jun 05, 2011 | Compaq Presario M2000 Notebook
Blue vertical line on my screen which disappears when i tap screen. had laptop for 3 years. amilo fujitsu siemens laptop.
Hi Sir. This is cause by a hardware failure. THe lcd that you are using has a dead line. It will not be restored unless you change your lcd.
Jan 23, 2010 | Compaq Presario M2000 Notebook
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Vertical line on right side
Your Display Screen is gone.
Replace it
Nov 17, 2008 | Compaq Presario M2000 Notebook
Line in lcd
Most of the time, symptoms like those appearing on your laptop are caused by problems with your video card or the LCD screen. One of the main causes for the problem is excessive heat buildup in the laptop that damages either component, or both of them. If you have a jack for connecting an exterior monitor, try hooking up a monitor to the laptop. If the problematic lines don't show up on your LCD, that;s the component that's going bad, If they are still visible, there's a good chance your video card is going bad (or both the video card and LCD screen are going bad).
Hope that helps isolate your problem.
Aug 11, 2008 | Compaq Presario M2000 Notebook
Try changing your screen desktop resolution to a different value. If you still have verticle lines, then try changing the color depth from 32bit to 24 or 16. If the problem remains your display adapter has completely failed. It has failed to compute column row addressing math.
Naturally, you would want to find and install the latest drivers for your display adapter with the hope that the failure is in the software driving the display adapter and not an onboard chip. If updating your drivers fails to resolve the issue you need to have service performed on your laptop. Most laptops have the display adapter soldered on the main circuit board and many shops are capable of replacing this chip set.
Yet, get a quote first as the cost might cause you to consider an upgrade into a laptop that has a display adapter that is Direct X 9c or Direct X 10 ready as that will run most of the new game titles coming out this year.
Let me know if you have any further need of assistance as you run through the above troubleshooting routine.
I do hope this has fixed ya!
May 16, 2008 | Compaq Presario M2000 Notebook
Vertical lines
LCD price rate about $2000 and if you buy in official service center just give warranty for 3 month.
My suggestion: Buy only in place that can give u 1 year warranty else buy the 2nd one for lcd than sale it!
Jan 07, 2008 | Compaq Presario M2000 Notebook
Problem with screen of Compaq Presario M2000
Plug an external screen to it and see if those nagging green lines have gone if it has you have a LCD problem. There is no solution to fixing that but to replace it?
Sep 20, 2007 | Compaq Presario Laptop
Compaq Presario M2000 Notebook Logo
199 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
