Question about Nokia N73 Cellular Phone
Nokia n73 i am trying to switch on my phone but woudent switch on when i connect to electricity supply it just shows battery charging but on off switch is not working
  • omar2 May 20, 2008
    I drop my phone, not a big drop and the phone
    displayed insert sim, I tried to turned it off but it wouln't so I took off the battery and now the phone does not want to turn on. when I plug it in , t shows that is charging. What the hell is all this about??
    Novelist:
  • 124 Answers
HEy dude,
I think the rubber inside the phone under switch button is damaged. It doesnt cost so much. Contact ur mobile technician. Ur mobile can be fixed in little time.
Send me a feedback and rate my solution too.
Dont forget to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
Posted on May 18, 2008
Cell phone doesn't start up by pressing power key.charging procedure showes when i plug it to charge.nokia n73
The Nokia N73 is a pretty old mobile phone for now.
Solution : Firstly check the battery of your phone. Try replacing it with an other battery model BP-6M.
If Problems solves, buy a New Battery(Model: BP-6M).
Oct 18, 2010 | Nokia N73 Cellular Phone
My nokia N73 mobile phone getting low battery fast. after charging the battery the battery power remains only up to maximum of 2-3 hours. i brought a new original battery to check whether its a defect of...
This is a very common problem with the nokia N73 phone,
The problem you are experiencing with your phone is not from the battery but rather from the panel of your phone,
The panel of your phone is corrupted,hence its irrationally discharging the battery rather than storing up the charge.
The solution is to ;
1.take apart the phone,
2.Conduct a thorough cleaning and servicing of the phone panel.
3.If problem persists,it means the panel of your phone is gone and needs a replacement.
Best of luck!!
Aug 13, 2010 | Nokia N73 Cellular Phone
N73 mobile is Switching off after one or two calls & light sensor is bot blinking. Battery is full charged after listing two to three songs, mobile get Switched Off. when we connect to charge the...
The Happy news is your phone is perfectly working.Only the battery is the problem.Your Battery is stone dead.That is it will get charged(Acting like it is charging).If you use your mobile the charge will go off soon.Is you battery is bulged?See any slight bulge in the bodPlease do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-) y of the phone..Replace the battery soon...
Jul 28, 2010 | Nokia N73 Music Edition Smartphone
I have a battery low problem after 1 or 2 hours after charging my n73 battery, i tried to change my battery but the problem is always the same. help me please
just minimise the backlight timing, make off the screensaver, switch on the power saver, don't switch off/on the phone, and most important don't overcharge and put ur phone on charging whenever it shows low battery alarm and remove as soon as possible as the battery is full, your battery will give you more backup.
Jan 29, 2010 | Nokia N73 Cellular Phone
Nokia n73 new battery charges quickly and
try without memory card and if problem persists pls go to customer care...
Aug 10, 2009 | Nokia N73 Cellular Phone
Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
Mar 07, 2009 | Nokia N73 Music Edition Smartphone
NOKIA N73 PROBLEMS
my n73 hand set problem is if i connect the charger on the screen displayed not charging, and i use to charge the battery charger to store power in battery. charger is working fine but hand set troubled me and the other problem is if i listen the music files after 2 minutes phone is off, in a day its happening lot of times give a complete repairing solutions.
Jul 16, 2008 | Nokia N73 Cellular Phone
N73 shutdown
chinese versions of nokia phones are duplicates and fakes, they are pirated. there is not much you can do with them and it is a big risk to buy one. i wouldnt advise you to get any chinese version of any nokia phone.
the only way you might charge it is through a universal charger. make sure you have connected the betery corectly and then charge it till its fully charged. if that does not work, try getin a new batery
Jul 12, 2008 | Nokia N73 Cellular Phone
N73 hangs while starting up
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
  1. Switch off the phone.
  2. Hold down the following three buttons: Green (call answer) button, * button, and '3' button
  3. While holding these buttons, press the power button and switch on the phone
  4. When the message 'Formatting' appears on the screen, release all of the buttons
Note that you shouldn't switch the phone off or remove the battery when performing either of these operations, and it's advised that the handset has a reasonable amount of battery charge before performing a format/reset.
May 16, 2008 | Nokia N73 Cellular Phone
Nokia N73 software update problem
during software update N73, the phone does not switch on. what can i do
Aug 07, 2007 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
60 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
