Question about Bosch Nexxt WTMC 3300 Electric Dryer
My dryer heatsp but the drum wont spin. - Bosch Nexxt WTMC 3300 Electric Dryer
  • Bosch Master
  • 43,501 Answers
If you are getting heat but the drum won't turn then the problem is usually with the motor or the belt. If the motor is running but the belt is off or broken then you should hear a faint hum of the motor running and the motor coasting to a stop when you shut it down...
If the belt is off and not broken then check the guides and wheels to make sure that one of them has not come out of alignment or broken throwing the belt off...
Also check out this tip...
DryerRepair - The Dryer is not Turning
heatman101
Posted on Sep 15, 2010
Dryer motor hums but doesn't spin
Sounds like the motor has gone bad.
May 10, 2015 | Amana Dryers
Lg DLE3777W wont start
if the motor is running and the drum is not spinning check the belt that wraps around the drum and motor. may have broke or just slipped off
Jun 21, 2012 | LG DLE2512W Electric Dryer
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
Drum wont spin
if dryer start but drum wont spin the you may have a motor pulley broken or a belt or idler broken. you have to open dryer to find out. some Maytags recently had problem with the motor pulleys but at factory they are making the changes to it on the new ones.
Feb 14, 2011 | Maytag SDG3606A Gas Dryer
Why wont the drum spin
does the motor spin when you hit start? If so the problem could be with the belt
Apr 27, 2010 | Kenmore 62802 Electric Dryer
My druer is heating but the drum wont spin
either the motor is defective or the drum belt is broken or off the pulleys, if you can't hear the motor start and run w/o belt attached and it just buzzes the motor start cap could be bad
Sep 30, 2009 | Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
47 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
