Question about Frigidaire GLEQ2152ES Electric Dryer
The dryer works, but dont heat, and apears the PF on the display
  • 4,323 Answers
Hi
Error PF means power failure, it appears when the dryer is unplugged or when an intermittent power failure is observed by the dryer. If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Posted on Sep 15, 2010
Displayed PF, when try to start, trips breaker.
any work done? call them back if so. Hope this is not a new dryer, if so hope it.s under warranty! Sounds like time to look for a lightly used replacement.
Mar 13, 2015 | Dryers
PF MESSAGE APEARS ON DISPLAY
the water level malfunctioning
Nov 07, 2013 | LG Washing Machines
My Frigidaire dryer will not start. It shows a PF trouble code. What does this mean?
PF is showing you that there is a power problem. Check your dryer circuit breaker at the power panel. This can be a sing that one of the 2 breakers has tripped. Push the CB hard to OFF and then back to ON. Then try and start your dryer. If that does not work just respond here and I will help you.
Try selecting "No Heat" after resetting the CB and see if the dryer starts. If it does you could have a bad heating element that caused the breaker to trip to begin with. Sometimes when the heating element fails the broken link will contact the chassis and cause the CB to trip. Heating element failures are usually caused by poor airflow. You may want to look for any signs of lint in your dryer to include the lint filter area and all the way to the outside wall exhaust point.
Kelly
Oct 01, 2010 | Frigidaire Electric Dryer
Power went out and dryer is blinking "pf" and no buttons work
It blinks "PF" to indicate that the cycle is interrupted due to a power failure. Press Start to continue the cycle or press Stop/Cancel to clear the display then restart the cycle.
Unplug the dryer for at least 30 minutes to forcibly reset the control if the display does not clear out or if the dryer cannot be restarted. Indicate the complete and exact model number of the dryer for further and specific troubleshooting repair advice.
Aug 22, 2010 | Kenmore Dryers
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Getting code PF, resetting breaker did not fix the problem. Dryer model Aeq6000es2.
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
The dryer will not turn on its flashing pf
Apr 15, 2009 | Whirlpool ET8CHEXSQ Dryer
Aeq6000es2 dryer getting error message PF
power failure...reset breaker for dryer restart cycle then it should be g00d!!!!!!
Mar 31, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
99 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
