FixYa.com
Tags:
Panasonic Workio DP-1820E Copier
DP-1820E shutdown the Print Spooler's Windows...
posted by bayuagus on May 16, 2008
I use DP-1820E as a network printer, so I installed the driver on a couple of PC. But some PC can't print on it. If I try to print, the Print Spooler service (windows's service) is stopped. I can turn it on manually. But in a few seconds, it's stopped again. Fortunately, it happened on some PCs only. Anybody can help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 27, 2008
Not Rated (0)
Onceoff
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the same problem so went to http://www.bayshoreoffice.com/drivers/#DP-1820E and downloaded the relevant driver. I needed the vista one. As suggested above just replace the old one with the new one. The zip file I downloaded also had instructions on how to do that.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 16, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Had same problem. Downloaded Standard GDI printer driver from http://www.bayshoreoffice.com/drivers/ dated April 11 2007 and overwrote old driver with the updated one (ver4.2 I think) and printing to DP-1829E was restored. Strangely PCL printing won't work at all!
Can you Help with these Copiers problems?
Copiers
Konica 7030 copier/printer -...
A service code of f 32-4 comes... Answer This...
Copiers
minolta
minolta ep 1030 copier paper... Answer This...
Copiers
cf323
same probelem Answer This...
Error E02-01
A loud clicking noise from time... Answer This...
Panasonic Workio DP-1820 error...
Anyone any idea what this... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
