Question about Dryers
I can't find the heating element in my Frigidaire stackable dryer.
  • 5,911 Answers
The heating element is BEHIND the dryer drum. You need to remove the drum in order to access it. Keep in mind, if you have a heat related problem, it may or may not be the heating element. It could also be the thermal cut-out (TCO) which is mounted along with the heating element. Again, you will need to remove the drum to get to it. The TCO acts as a fuse and is designed to blow to protect the heating element if it overheats. Check the TCO first to make sure it is not blown. If you need further assistance, please post back with your MODEL NUMBER. I hope this helps you.
Posted on Sep 15, 2010
  • donald c. ray Sep 21, 2011
    how do I take it apart, model no. gle0642as2
Frigidaire stackable dryer model gleh1642dso not heating up
Did you checkout the heating elements for continuity? Are they receiving power? If not, why not?!
Aug 30, 2016 | Frigidaire Dryers
Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
Aug 25, 2008 | Frigidaire GLEQ642A Electric Dryer
NEED TO INSTALL HEATING ELEMENT ON MODEL FEX83ICSO STACKABLE DYER
This is it, Good Luck Tim:
http://www.partselect.com/dryer+replace-heating-element+repair.htm
May 26, 2011 | Frigidaire Dryers
Dryer runs but no heat. Stackable set, dryer on top.
More than likely the Thermistors are blown. They are located on the heating element canister inside the dryer, they are kinda oblong shape with two electrical connections. If you have a multimeter you can check for continuity on the thermistors and the heating element just be sure to disconnect one of the electrical connections on the thermistors and the heating element so you don't get a false meter reading, Thermistors can be purchased from most appliance repair businesses for around $30.appliancguru.jpg
Dec 10, 2010 | Frigidaire FGX831CS Top Load Stacked...
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
I cant find the heating element on a stackable fridgerdaire dryer
it is located in the cabinet of the dryer behind the drum the top needs to be removed and the front panel needs to be taken off then the drum removed
Sep 05, 2009 | Frigidaire Dryers
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
126 people viewed this question
Top Dryers Experts
