Question about Goldstar DH504EL Dehumidifier
Dehumidifier runs loud
When I turn my system on it starts fine then within 45 sec it starts running in a really high gear and very noisy. It also freezes the coils after a period of time and will not collect water anymore. Is there anything I can do to fix these problems?
  • 828 Answers
What is the temperature in the space where you are operating thsi dehumidifier? When you first start a refrigerating system some refrigerant may have condensed into the compressor oil. When the compressor starts the pressure in it drops rapidly. The oil boils and some passes through the compressor valves. After a few minutes of operation this condition normally corrects itself.
Posted on Jun 06, 2008
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
My dehumidifier runs and the refrigerator or cooling unit turns on, but no water comes into the bucket? Last year it was running fine? fans run and the humidity level is high in the basement
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 09, 2011 | LG LHD45EL Dehumidifier
My humidifier dont collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
May 16, 2011 | Maytag Dehumidifiers
The dehumidifier runs for a few minutes and then shuts down. The humidity indicator shows that the humidity is 75% high in the room that it sits and I have it set for 40%. I'm thinking that it's a timer...
heatman101
Apr 12, 2011 | Haier 45-Pint Dehumidifier
Sometimes the machine will run and sometimes it will do nothing when it is turned on. When it does run there is never any water collected in the bucket. I have let it run for as long as 12 hours and still...
heatman101
Aug 25, 2010 | Haier 45-Pint Dehumidifier
My Haier dehumidifier is really noisy. If we turn it off and restart it, it will run quietly for maybe 4 minutes and then start getting really noisy again. Any ideas what is causing it and what I can do...
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 14, 2010 | Haier Dehumidifiers
Dehumidifier trips ground fault outlet and no water in bucket
The compressor is trying to start and pulling high amps which trips the GFI...
You are better off replacing rather then repairing that unit.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 17, 2010 | Haier 45-Pint Dehumidifier
Haier hd656e, my dehumidifier runs about 30 sec and turns off,
This sounds like a main circuit board problem and is very common with many dehumidifiers... They can be replaced on some units. You can do a search online for the part easily...to see if it is available.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
heatman101
May 16, 2010 | Haier HD656E Dehumidifier
Really thick ice on back of dehumidifier
It is now frozen because the humidistat, which controls the on/off cycle, is starting to age and forgetting to turn off the dehumidifier. Try removing the humidistat and, using compressed air, blow it out thoroughly of any dust. Then spray the rotary control area, including electrical parts, with WD-40. Then, blow dry again with the compressor and try again.
Jun 23, 2007 | DeLonghi DDE50E Dehumidifier
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Goldstar DH504EL Dehumidifier Logo
310 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
