Question about Intel Computers & Internet
Intel Proset wireless connection and Windows wireless connection are fighting for rights to connections. How do I use just the Windows Wireless connection? I need to disable the Intel Proset wireless connection program. Need help to connect to the Internet
    Brigadier General:
  • 10,406 Answers
If the Intel ProSet application has an icon on the bottom-right of your "system-tray" (the system-tray has the START button on the left and the clock on the right), then right-mouse-click on that icon, and choose 'exit' or 'close'.
Posted on Sep 15, 2010
While trying to add another computer to my wireless connection, it asks for a Device Ownership Password but it will only allow numerical digits (8). Help?
Using Intel ProSet Wireless, right? Use Windows utility and it will be fine. I still have not resolved this with ProSet.
Sep 20, 2010 | 2wire Computers & Internet
Dell Inspiron E1505- Intel(R) PROSet/Wireless 3945BG Network. I also have Comcast Cisco modem and cisco Linksys router. I was getting an error "problem applying profile". I went to the contorl...
I had usualy solved mysterious problems with other intel PRO wireless cards not authenticating, loosing signal, etc, by simply upgrading to the latest intel drivers.
Also using the Intel connection manager instead of the windows or Dell/other notebook manfucaturer's product is far more reliable.
Hope this helps.
Feb 09, 2010 | Intel PRO/Wireless 3945ABG Network...
Intel ProSet Wifi software can't connect to network
You need to manually add the network using your intel pro set utility. Or just switch to wzc.(wireless zero configuration). How to do it? just click start - go to run - type in services.msc - then look for wireless zero configuration on the list - right click on it then click start.
Then look for the wireless network connection icon on the system tray (that's in the bottom right hand corner of your screen). right click on it then select view available wireless network.
note: if you'll be getting the message "windows could not configure..." click change the order of preferred networks(that's in the same window where you're getting that message) then check the box that says "use windows to configure my wireless network settings" then click ok. after that go back to view available wireless networks then you should see your network now.
note: if you're using a corporate laptop where you don't have admin rights on it you need to use the intel pro
Dec 28, 2009 | Linksys Wireless-G WRT54G Router
Something wrong with software causing wireless connection issues
Make sure you are using the application that came with your computer to work with the wireless card. The windows embedded application is a generic program. The application that comes with your computer/wireless card will work better or is made to work with that adapter. You can turn off the windows wireless zero configuration by going to:
Start -> Run -> Type "services.msc" hit enter
Scroll down to the bottom and right click on Wireless Zero Configuration and click Stop.
Use the Intel PROset Wireless application which are used in most Dells.
If you are stilling having problems, try uninstalling the PROset Wireless Application, Updating the Wireless Drivers and Reinstalling the PROset Wireless App.
This link
will help you
Aug 02, 2009 | Dell Studio 17 Laptop
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Jul 03, 2009 | Acer Aspire 3000 Notebook
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Iam connected to the wireless network but cant access internet
right click my computer
then properties
hardware and then devices
scroll down till you find your network
click it and then update
after updating restart
let me know if that helped
Jan 18, 2009 | Acer Aspire 5315 Notebook
Ip Address 169.x.x.x Wireless Internet Connection Problems 6400/E1505 Dell Laptop
questions to ask yourself:
- I the wifi card connecting to the routers wifi network? or your next door neighbors?
- did it connect with the correct WEP? withouot the right WEP it will not communicatwith the WAP
- is the router set to be the DHCP server? this function is normally defaulted to ON
some times though windows simply has to have its TCP stack reset after having been connected to too many different networks, especially if you are a heavy wifi user.
open a command prompt: I see you already know how.
Type this command line
netsh int ip reset <anyfilenameyoulike>.txt
the txt file will be a log file tha will be placed on your main (c:) drive after the NETSH command has run
next lets reset winsock since we are here in the command line anyhow
netsh winsock reset
if everything goes right you'll be prompted to reboot you machine.
hopefully this will solve your inability to aquire an IP address from the router.
Jan 04, 2009 | Acer Aspire One PC Notebook
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Nov 05, 2008 | Acer Aspire 3000 Notebook
Wireless network not detected despite all elements seems working
Hello there.
This is a common problem. What i typically do on notebooks that use Intel Wireless, is install the latest drivers and Intel software from their website. 9 times out of 10 this will make it pick up a network that was not previously found, or fix problems with timeouts and so on.
Please click here then choose your version of windows, click 'Go!' and then click "Download" beside the section called "Intel® PROSet/Wireless Network Connection Software for Windows* XP/2000 32-Bit"
When you download and run this file, and install the software, you can then use the Intel utility to connect to the wireless network.
Hope this helps.
Jun 16, 2008 | Intel PRO/Wireless 3945ABG Network...
Computers & Internet Logo
175 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
