Question about Whirlpool WED5500X Dryer
WED5540SQ0, not heating. Continuity of coil, therm and coil ok
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 15, 2010
No heat
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Sep 26, 2010 | Frigidaire Electric Dryer
How do I tell if the heating element is burnt out?
Sep 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat in cloths
Sep 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
No heat
Sep 26, 2010 | Kenmore 600 6965 Electric Dryer
MY DRYER WONT HEAT UP
Sep 26, 2010 | Maytag PYE2300AY Electric Dryer
How do i get to the heating element of my dryer
Sep 25, 2010 | Speed Queen AES28AWF Electric Dryer
My dryer is not heating
For this FREE answer, Please rate me
Sep 22, 2010 | Whirlpool WED8500S Electric Dryer
Will not heat up.
Sep 22, 2010 | KitchenAid Dryers
My dryer no longer has heat
Sep 22, 2010 | LG DLE2512W Electric Dryer
Dryer won't heat
OKAY,please always state exactly what kind of appliance you have.
you need to replace the coils which is located on burner, there are 2 black gas coil.
there is also a flame sensor on the left side of burner, get a meter and check for continuity.
on kenmores there is a white fuse on the back of dryer that goes bad.
Sep 11, 2009 | Kenmore Dryers
Whirlpool WED5500X Dryer Logo
165 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
