Question about Philips 27PT9015D 27" TV
Hello I have a philips 27" flat tv it's about 4 years old and i am getting 1 red 1blue and 1green line that runs across the screen about 2 1/2" -3" down from top and several lines from there to the top iv been told by a friend that is experiencing the same problem that the FILTER IS DIRTY does this sound like the likely problem?
rix20601
  • 24 Answers
SOURCE: TV Problem
No. Are the lines white or black? Does the picture look distorted at the top? Is there a chance it is still under warranty? It sounds like a problem in the vertical retrace circuit. Probably a capacitor near an IC that's used for timing. You shouldn't be having this issue already. A tech should be able to see a distorted waveform in the vertical section. Hope this helps.
Posted on Nov 11, 2006
  • 45 Answers
SOURCE: POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Posted on Nov 04, 2007
techman
  • 3130 Answers
SOURCE: philips tv
You have bad capacitors in the vertical sweep circuit. If you have no electronic repair experience, you will have to take the set into a repair shop as these parts are soldered into a printed circuit board and need to be tested with an ESR cpacitor meter. Good luck
Posted on May 27, 2008
freetek
  • 5568 Answers
SOURCE: 32Inch Flat Screen SDTV - with picture distortion
If you have a TV shop at all any more in your area, any tech working on them will know where to look. This is a pretty common problem although you are getting it too early.
Since it will require a certain type of instrument (capacitance meter) to verify the problem part, I don't want to go into detail concerning a 'do-it-yourself' repair since it may be a little difficult to order these in single quantities and a decent shop should have the right value on hand.
It shouldn't cost too much.
Posted on Jun 28, 2008
Siestamagic
  • 6 Answers
SOURCE: Philips 27PT6441 27" TV Problem
jon5902,
Pls note that my experience is with the phillips 27" model27PT6341/07. It may not be the same board as yr model, as I can't remember nor find the service manual anymore. (browse around online for it though)
However, after taking the back off. Look close to the rca jack and svideo connection. Mine is located about an inch from the svideo connection.
Here are some pics that may help you.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
The new one is the black and gold one marked 10uf 100v in the pic.
Other users have advised to go as high as 10uf 250v, to avoid having the cap overload again.
PS. I had the lines for about 2 weeks. They got steadily worse then one day my tv looked like it was broadcasting an hourglass. The lines converged in the center and flared outward (no pic).
Posted on Sep 12, 2008
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Picture split
use one red the white and then try both green or blue with red and white
May 01, 2009 | Microsoft Xbox Console
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Shuts down
it is due to problem in red cideo section. solution 1 supply to red video output& output itself 2 crt base loose 3 connector loose 4 red video sigal line from chroma ic to red cathode of crt. 2 red
Nov 13, 2006 | RCA 27V520T 27" TV
Philips 27PT9015D 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
