Question about Precor EFX 546i Elliptical Version 4
I own a precor EFX 5.21i, I recently began to get a error 40 message. I was told by precor it could be a blown fuse or bad lift motor. Where do I locate the fuse? emartins54@comcast.net
  • Precor Master
  • 914 Answers
Please verify before ordering, but this will get you on the right track.
Fuse 4 Slow Blow 250V 5 20mm PPP000000010719121 SPORTSMITH net
Posted on May 15, 2014
5 Suggested Answers
  • 13 Answers
SOURCE: i pulled the plug on my precor efx and now it wont
yes, we can help. 281-469-8506 www.nashsfitness.com
Posted on Aug 10, 2009
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
maxtreadmill
  • 832 Answers
SOURCE: belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Posted on Mar 13, 2010
ZJLimited
  • 17970 Answers
SOURCE: How do I replace the
Check this reference guide in video: Precor+elliptical+trainer+change+belt
Hope helps.
Posted on Dec 28, 2010
Error 40 on precor c964i
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 40
Feb 22, 2014 | Precor EFX 546i Elliptical Version 4
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
What does error code 40 mean on the Percor efx 5561?
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Feb 14, 2012 | Precor EFX 546i Elliptical Version 4
Precor efx 546 error 40
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jan 30, 2012 | Precor EFX 546i Elliptical Version 4
PRECOR EFX 546 ERROR CODE 40
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Oct 17, 2011 | Precor EFX 546i Elliptical Version 4
EFX 546, there are 2 fuses on the board F1 and F2. Can you tell me what they are for and what the amps are? I know they are both 250V. I am getting error 42 and was told to check these. Thanks Jen
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
Aug 15, 2011 | Precor EFX 546i Elliptical Version 4
My precore is now in the basement and has error 40 code showing and it is squeeking. Im sure it should not be in the basement obviously there is too much moisture. Is that what error 40 means?
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Mar 10, 2011 | Precor EFX 546i Elliptical Version 4
Precor efx 546 error code 42
Model: All Models
Recommended Action:
Nov 30, 2010 | Precor EFX 546i Elliptical Version 4
Whenever I use our eliptical precor efx, as soon as the elevation starts it says error 45
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Aug 10, 2010 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
624 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
