Question about Vacuums
How do i change a light bulb on a hb-4190 series hampton bay outdoor lantern?
Trying to find a replacement globe that is transparnt or translusent for a hampton bay 31133-22
Hampton Bay (Home Depot) has a toll-free number for you:
(877) 527-0313 (Monday - Friday 8 a.m. to 6 p.m., EST)
Mar 02, 2011 | Vacuums
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Oct 11, 2010 | Vacuums
Can I use a regular 2 conductor cord set on a ceiling track lighting kit and plug it into the wall? I Dont have a box in the ceiling
Yes, but make sure to use a polarized male plug ( the one with the slightly larger prong on one side).
Aug 22, 2010 | Vacuums
Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Jun 06, 2010 | Vacuums
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
