My Sanyo tvs sound does not work on TV/Cable mode. It works fine on all other modes (video 1, Video 2, Component, etc)
tvtek
  • 1284 Answers
SOURCE: "No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Posted on Feb 08, 2007
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
philipp
  • 217 Answers
SOURCE: Menu Options
sound or volume can be lowered or turned off using zoom control button
Posted on Aug 31, 2007
simplemitch
  • 752 Answers
SOURCE: poor picture with hdtv Hitachi 37HDL52 plasma
What EXACTLY is wrong with the picture? Is it black and white? Green? not there? distorted? need info...
Posted on Sep 20, 2007
  • 10 Answers
SOURCE: Blue Vertical Line- Akai PDP4298ED
TRY THIS USING THE REMOTE. 1-PRESS BRIGHTNESS 2-PRESS THE FREEZE KEY 3-PRESS THE MENU KEY 4-PRESS ENTER THIS WILL RESET EVERYTHING.
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
My tv is stuck on the video imput for my Wii and none of the front panel buttons work
Try to see if any of these four methods will work.
Sanyo TVs
1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote
2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV
3. Press TV/AV or INPUT SELECT on remote
4. Press SETUP, choose TV/AV, switch to AV
Sep 25, 2011 | Panasonic TH-42PX60U Television
What channel or setting is used on the TV to play a DVD?
Hi, Channel 3 or 4 might work for older TVs. Most new HDTV's have a mode setting in the menu. (Video 1 or 2 or 3) or (Component 1 or 2). On your remote you may have DVD button. Try all these suggestions, 1 of these will work. You can play with the remote too. Good luck.
Jun 13, 2011 | LG 42LB2R 42 in. LCD HDTV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Trouble with 360 and hdtv
The cable your refering too are called Component leads.
The red and white are for your audio and the remainder are the video. All you need to do is connect the component leads matching up all the colour in the correct ports then using your av/source button change the tv to component
You will still have to connect the red and white audio cable to the tv as well.
that should sort your xbox out.
cheers
Little Dish Fitter
Sep 18, 2009 | Proscan PS36700 36" TV
Finding Recording/Playing Channel on TV
Make sure there is a yellow video cable (or one of the other types of video cable) running from the Philips to your Panasonic. Make note of how the TV labels that source - Video 1, Video 2, Component 1, etc. Use the TV/Video button on your Panasonic to change the TV to the appropriate input channel - Video 1 or 2 if you used a yellow video cable, Component 1 or 2 if you used a red/green/blue cable, etc. Now, make sure that the Philips is in Disc mode by pressing the Disc button on the Philips remote. You should now have picture.
-Tha Mp3 Doctor
Oct 22, 2008 | Philips HTS-6500/37 System
The who input button
usually a tv that doesn't "see" video on the S-video will not even "switch" to it.  It just goes to the next Svideo, RCA etc..
Make sure your cable is not damaged. (on both ends) Does the svideo source and svideo cable work with another tv or video device?
31GT740 Manual From the Manual:   " WHO•INPUT In TV mode, press WHO•INPUT to toggle through the available Video Input channels (VID/SVID and the current channel). In SAT mode, press to select available channel lists.
Using the WHO•INPUT Button Use the WHO•INPUT button to toggle through the available input sources (VID and the current channel) and view the content from the component you have connected to the TV. 1. Press TV to place the remote in TV mode. Make sure that the content from the component is turned ON. 2. Press WHO•INPUT to tune to the available input source and view the component. 3. Press WHO•INPUT again to tune back to the channel you were previously watching.  "
James Mac
Sep 10, 2008 | GE 31GT740 31" TV
TV (Model DS27510) is stuck on Video2 setting, unable to change!!
Ours is doing the same thing except on Video 1. I called Sanyo customer service and they said I need the original remote. They were willing to sell me one for $20. Here is what I did instead. I used a cable box and hooked the cable in to it. Then I took the type of cables that will hook into my video 1 slot and plugged them in there and plugged them into the back of the cable box in the "cable out" positions. It worked ! If you do not have a cable box you might try a DVD/VCR combo or a VCR. Good Luck
Sep 16, 2007 | Sanyo DS27510 27" TV
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
