Question about Neptune FB1621 Murano Toilet
I need to find a parts for neptune toilet the whole kit including seat
I am looking for a toilet for my Neptune toilet. I want a white elongated quiet close and quick release seat like the Kohler 4636-0. Can I purchase this at Home Depot or equiv.
They should be able to help you . They have a website you can use to find parts you needed. As do other d i y stores.
Oct 22, 2017 | Kohler Home
NEED TO REPLACE THE SEAT AND COVER OF THE TOSCA TOILET
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=365570&chnl=cse&ven=googlebase&cat=Bathroom%3AToilet%20Seats&brnd=Herbeau&itm=0651'Herbeau%200651%20Monarque%20Toilet%20Seat%20and%20Cover%20Only%20in%20Plain%20White%20-%200651
The picture shown with your post shows a toilet seat that looks like the one sold at site above.
But the site above is selling the toilet seat called the Monarque toilet seat and cover.
The particular seat shown is not called a Tosca.
Another site shows the identical whole toilet, and calls it the Herbeau
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
The pdf from Eljer showing the Tosca toilet looks very similar to both the products shown on the two links above. Maybe this solves the question.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Dec 05, 2010 | Eljer Toilet Seat Tosca 124200000
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
My toilet seat broke, where do i geta replacement?
Unless there is something unusual about the seat you should be able to buy a standard replacement seat at Home Depot or Lowes. They come in round and elongated and there are a number of styles available. Measure the distance between the center of the mounting bolt holes and match with the display to see if they will work.
May 24, 2010 | Neptune FB1635 Catania Toilet
Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Feb 13, 2010 | Neptune FB1621 Murano Toilet
Get seat of Kohler K-3386
Roberta3fan could be giving bad advice based on experience with other toilets. This does not seem to be an option for this toilet design. I am in a similar situation and it appears that the nut (and it is a metal bolt) is not what you would expect. Here is a picture of the anchor kit for this toilet seat: http://www.plumbingsupply.com/images/kohler-anchorkit-84999.jpg I am going to assume that the sleave that should be engaging the bolt is cross threaded and try to grab it with a pair of vice grips. I'll let you know if it works.
Jan 09, 2010 | Kohler K-3386-0 Rialto one-piece...
MAH4000AWW Bearing Noise When Spinning
12002022 is a seal kit only. The outer tub replacement is the correct fix, The part number for your unit is 22002907 and crosses over to 22004465. BTW. the replacement tub includes the seal kit and for the price I usually change the spinner assy at the same time..There are two part numbers for that.. It depends on your washer series which is determined by the first 2 numbers of your serial number... Hope this helps... Bill
Apr 18, 2009 | Maytag MAH6700AWW Neptune Front-Load...
TOTO WASHLET LEAKS!
from where?? If it is leaking on to the floor from the base of the toilet you need a new wax ring installed,,, if the water is comming out from where the tank bolts to the bowl you need to get the proper kit since it;s a toto they are one of a kind and don't have any universal kits that will work, call or e-mail toto tell them you need the tank to bowl kit, might as well tell them to send the flush valve also and just do the whole thing good luck
Feb 20, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Neptune FB1621 Murano Toilet Logo
332 people viewed this question
Top Neptune Home Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
JonSnell Electronic
JonSnell Electronic
Are you a Neptune Home Expert? Answer questions, earn points and help others
