Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool Duet Stem Washer Code 35 - Whirlpool Duet 4.0 Cu. Ft. Steam Washer
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 27, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
F-35 code My washing machine Whirlpool duet steam machine keeps going into the F-35 Code and stops washing.  I don't have the book.  Please, if anyone knows what this means or how to fix it, my email is...
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Sep 12, 2008 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washer wpl duet WFW9400SU- error code F35
F-35 is a common complaint on these washers. The analog pressure doohicky is at fault.
11_3_2011_7_31_28_pm.jpg Nice Replacement video
Nov 01, 2011 | Whirlpool GHW9400 Duet Washer
Washing machine Front Loading Automatic Washer showing error code 35?
Hello This would be a pressure sensor failure.
Will need to be replaced.Whirlpool has them in stock or you can have a service person come out.
Jul 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code f 35 on whirlpool duet washer
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Aug 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F-35 is showing on my whirlpoot steam duet stackable front load washer, what does that mean? It won't run through any cycles.
it is an analog pressure sensor failure theres a malfunction with the steamer component detected by the steamer electronic board
check if pressure hose is fixed correctly
check if the airtrap is not blocked
check if the hose is not blocked
hope this helps if this doesnt work write me back
Jul 21, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
What does F 35 mean on the front load washer? it's a whirlpool duet steam
it may be a problem with the pressure switch clean it out and see if this clears the error code
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet sport F 20 code
common F20 error requiring an about $35 water valve replaced. You can get parts and manual at repairclinic.com
Oct 14, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet washer Displays F 35 code and stops
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal De
