Question about Toro Super Recycler Super Bagger Lawn Mower Rear Bagger 5
I have a Toro super recycler model 20017 with a tecumseh motor, model LEV120, spec 361541B has spark and is getting fuel but will not start any suggestions? Have already replaced coil cause previously had no spark. I have taken apart and cleaned the carburator. Also tried the spark plug in a different mower to see if it was the problem but started that mower with one pull.
    President:
  • Toro Master
  • 1,545 Answers
Make sure that the doggone brass bolt that holds the carb bowl on was cleaned as well. It is the main jet and has tiny holes that get clogged from evaporated fuel/varnish and debris (if no inline fuel filter is used). It has holes on the bottom and the smooth part of the sides...it needs to be clean and shiny! If all is well and the motor is an OHV, then maybe the valves need adjusting.
Posted on Sep 14, 2010
  • 1 more comment
  • Roy Cagle
    Roy Cagle Sep 15, 2010
    Make sure you air cleaner/intake system is clear and clean. (when working on these I have been known to leave a paper towel piece in the intake tube to keep dirt from entering)....and a no start condition was born!
  • hd1200custom Sep 15, 2010
    I did take the bowl nut off and clean; holes were not plugged but had some build-up. Turns out the cable from the handle to the kill switch had some slack due to age and was not fully disengaging. Tightened it up and 1 pull and running like a top. Thanks for the suggestion.
  • Roy Cagle
    Yes sir...I've had that smae problem before...no action in the brake liner on the flywheel, Im glad you discovered that and my apologies for overlooking that as a possible problem. good job and thank you too.
Where are carb adjustment screws on toro lawn mower model 20017
the Tecumseh carb. does not have any adjustment screws. What is the mower doing wrong ?
Jul 09, 2014 | Toro Power Lawn Mower
Motor was losing power and burning
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
I have a toro gts 6.5hp model 20017. The enginer is overreving a lot. I had changed the carburetor and believe i put the linkages correctly, however i noticed the governor arm is rotated slightly right...
The way i set the govenor is, slacken the screw on the engine govenor arm, push the arm fully over to open the throttle wide open, now turn the actual govenor shaft within the arm in the same direction, fully retighten the govenor arm screw,
Sep 29, 2013 | Toro Super Recycler Super Bagger Lawn...
TORO RECYCLER LAWN MOWER MODEL 20017 2006 EDITION
to far away for me to look at it i'm on the east coast
Sep 01, 2012 | Toro Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
My spark plug wire was damaged. I went to Toro dealer and bought a new coil, and new rubber boot for spark plug. It was easy to replace, but after it started up, which it always does on first pull, I...
The contact point that grounds out the spark is not connecting. Take it apart back down to where you have access to the coil and check the mechanism and and the wire to ground out the spark.
Sep 02, 2011 | Toro Garden
Toro recycler 20017 is very hard to start. it has to be primed many times. after it run a while it starts on one pull.
The carburetor may need to be serviced. You need to find a parts shop that handles Tecumseh parts. You will most likely need a rebuild kit for the carburetor. The carburetor part number is 640303. The rebuild kit is 632809. The Tecumseh engine company shut its' doors 3 years ago. Finding parts is becoming harder and harder. I've heard that someone has bought Tecumseh over the winter but it is unknown when the new parts will hit the market. Best of luck to you.
Apr 03, 2011 | Toro Power Lawn Mower
Need replacement engine or short block for Tecumseh LEV120-361541B
Tecumseh has gone bankrupt so finding parts and engines has been difficult. i would see if i could find a B&S engine with the same bolt pattern to mount on the deck.
Sep 30, 2009 | Toro Lawn Mower With Toro Power Tools
BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER THE ENGINE IS A TECUMSEH MODEL lev120 SPEC 361541b 195cc
If you had replaced the flywheel key & did not engage the saftey bail it would brake the brake. Make sure the bail is engaged befor installing the flywheel.
Sep 23, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Super Recycler Super Bagger Lawn Mower Rear Bagger  5 Logo
761 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
