Question about Minka Aire Ceiling Fan
UC9040T Red light. Ceiling Fan not working no lights does not turn etc
SOURCE: Redington IV Hampton Bay Ceiling fan lights don't work and we don't know where the receiver goes.
I have the same fan. You have wired it wrong. The receiver goes under the collar cover. It is a tight fit but it is the quietest fan I have.
Posted on May 27, 2008
dutchman05
  • 487 Answers
SOURCE: Ceiling Fan Light Switch Has Busted
The pull cord light switch you can buy at any lowes or homedepot ( or hardware store) cost will be about 3-6 dollars
Posted on Jun 21, 2008
  • 234 Answers
SOURCE: installing a ceiling fan with light. extra red wire
The red wire is the power for the fan
Posted on Mar 14, 2009
  • 323 Answers
SOURCE: remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
Posted on May 26, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Posted on Aug 13, 2009
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
We have a UC9040T switch that stopped working after our power went out. Any suggestions?
I have minka aire uc9040t wall controller. If there is no green light make sure you have power to the controller wall switch. Mine had power but no green light, remove and disconnect the controller, open it up, remove the back plastic cover, you will possibly need to replace the internal 5 amp fuse that is soldered in. It is labeled on the bottom of the circuit board, and is encased in rubber heat shrink tubing. You will need soldering tools and skill. Mine was blown, replaced - works now.
Sep 10, 2011 | Minka Aire Ceiling Fan
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
I have a minkaie switch model uc9040t, I went to turn the light on, on the fan and it blew the light and now when I look at the switch on th on position the green light is off like there is not electricity...
I have a minkaie switch model uc9040t, I look at the switch on the on position the green light is off like there is not electricity coming to the switch, but itested the cables and there is electricity, and of course the fan won't turn on either, is there a way to reset this switch
Jan 31, 2011 | Minka Aire Ceiling Fan
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Minka Aire Ceiling Fan Logo
471 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
