posted by wasdat on May 16, 2008
Put in lubricant sheet and shredder worked fine for aobut 20 sheets, then it jammed. Looked inside and found shreds jammed in all the empty spaces and five tines impacted with paper that I could not remove. Spent more than and hour removing al the sreds and trying to clean the tines with the help of three libricant sheets,
Shreeder works fine in reverse, but only tolerates one sheet before quitting. How can i ge the paer on the times off?
Jane
1 Other User Has The Same Problem
Comment by deadshred, posted on Jun 03, 2008
after using lubricant sheets shredder was fine for a while . Now every sheet wr4aps around the teeth and I cannot get if off because it is wrapped so tightly around. Please help.
Suggest a new solution for this problem
Post a New problem for OfficeMax Shredder
Email this problem
Email this problem
Can you Help with these Shredders problems?
OfficeMax (0M96431) Shredder
OM 96146 Shredder will go in...
Able to reverse, but will not... Answer This...
officemax shredder OM96146...
The paper is getting carmed in... Answer This...
Shredder OM99731 is jammed
Hello: My OM99731 shredder is... Answer This...
Office max shredder om96431
the shredder will work in... Answer This...
Repair Service
Find Shredder Repairman Near You:
