Question about Dell Inspiron 6400 Notebook
The computer is getting power, but will not turn on
  • Dell Expert
  • 393 Answers
Remove both ram clean both ram and ram banks and return oen by one ram and check display.. Thanks
Posted on Sep 15, 2010
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Ive got a long continual beep and it emits orange light from the front and back of the computer how am i to fix it?
Unplug the power cable.
Remove the video card.
Remove the RAM.
Re-insert the video-card, ensuring that it is "seated" properly.
Do NOT re-install the RAM, just yet.
Connect the power cable.
Turn the computer on.
If you get a different "beep", the lack of RAM is the problem.
If you get the same "beep", the video-card is the problem.
Disconnect the power-cable.
Re-install one stick of RAM (two if it is RAMBUS/RDRAM).
Reconnect the power-cable.
If it beeps "normally", then the not-yet-installed RAM is the problem.
If it still "long-beeps", turn the computer off, disconnect the power-cable, and remove the RAM, and insert the "other" stick/pair of RAM.
Reconnect and start it up.
If still a problem, change the video-card.
Dec 02, 2009 | Dell PowerEdge 1800 Server
Power button
You have faulty motherboard my friend.Time to get new laptop as it is expensive to change mb
Nov 18, 2009 | Dell Latitude D600 Notebook
My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Sep 03, 2009 | Dell Dimension 4600 PC Desktop
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
Won't turn on - power led comes yellow & blinking
Please perform the steps mention:
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. Good Luck.!!
Aug 27, 2009 | Dell OptiPlex SX270 PC Desktop
No powering on
Resolution:
Aug 24, 2009 | Dell Computers & Internet
Computer in safe mode and monitor will go to sleep mode....help what can I do...my husband tried everything....
First, Shotdown your computer from start ,
then remove your computer power, remove VGA cable, remove VGA power cable. then
1- connect vga cable to computer.
2- connect VGA power but do not power on.
3- connect computer power on but do not turn on
4- turn on computer first and 3 second turn on your lcd.
if NOT try powering on computer then Monitor then power the computer then monitor.
IF NONE worked, YOU may have LCD that need drivers from manufacturing, some newer models required that, Specially for vista.You may use older Monitor to get drivers to computer and extracted, then you may connected, you will have solved the problem.
Goodluck
JMC
Aug 12, 2009 | Dell Dimension 4600 PC Desktop
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Power issues
Was one of the tips on the HP site to unplug your Video Card?
The power supply might be having trouble pumping enough power into the card.
After you take out the card and get it to POST, go into the BIOS and turn on the onboard graphics and see if you can get it back to the OS screen.
If that doesnt work post again and ill try to help you further.
Nov 29, 2007 | Intel Motherboard
Dell Inspiron 6400 Notebook Logo
23 people viewed this question
Alun Cox
