Question about Ebac BD80 Dehumidifier
Coils do not get cold - Ebac BD80 Dehumidifier
  • Ebac Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Mar 07, 2011
Ps 121a the air condition works fine but no water on dehumidify. filters are clean
-Is it very cold...? If not cold then it doesn't build ice around the
coil. That's why there is not humid.
Humid is created by the melting ice that builds around the coil.
Good luck
Mai
Dec 19, 2017 | Dehumidifiers
What causes the dehumidifier to freeze up
It gets too cold. The reason it gets to cold is that the humidity is not condensing on the coils. Did the water level submerge the coils?
May 11, 2017 | Dehumidifiers
Need a repair shop in the baltimore area to look at my dehumidifier runs but wont pull water
It's cold outside. If the temperature is too low, the cold coils will just frost up and you won't get much water 'pulled'.
Check to see if the cold coils actually are getting cold when the unit is running and the control is set to cause the compressor to work-not just the fan.
If the coils are cold and full of frost or ice, the room is too cold for the dehumidifier to work. You'll have to raise the temperature of the room or wait for warmer weather.
If the coils never get cold, the compressor might be bad or the unit might have lost its freon.
I wonder, though, if it's just too cool and dry right now for a dehumidifier to be pulling more moisture out of the air.
Hope this helps!
Jan 01, 2011 | Haier Dehumidifiers
Freezing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground).
Turn the unit off until the room warms up.
Good luck
Aug 19, 2010 | Kenmore Dehumidifiers
Freesing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
Aug 19, 2010 | Kenmore 5230 Dehumidifier
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
Take care.
Aug 10, 2010 | Fedders A7DH45B2A Dehumidifier
Fan and compressor run but coils not cold and no dehumidification is happening.
If your compressor is running but the coils are not getting cold, then you have a problem in your refrigerant circuit.....Most likely a restriction or a leak with a leak being the more likely of the two.
Apr 30, 2010 | LG Dehumidifiers
Unit runs but no water collects in bucket. Unit is over a year old and has run continuously that whole time. Up till now it has performed beautifully. Is it just worn out?
Hi;
Your dehumidifier is similar to a refridgerator or air conditioner. It has a compressor and coils, and a fan. Basically, the unit has to **** in air with it's fan, and as the humid air goes across the cold coils, the humidity condenses in to water. If the coils are not getting cold, they won't condense any water, or if the fan isn't running, or the coils are dirty. If you check your unit over, see if you can tell if anything isn't working. Make sure the control knob is set at the highest setting. If the compressor lost it;s refridgerant charge, and won't get cold, it isn't probably worth fixing
Nov 23, 2009 | Whirlpool 75-Pint Dehumidifier
Coils don't get cold enough to condense water
It will definately need a charge, however by the time you pay someone to come and service the unit a new one will start looking pretty good!
Sep 09, 2009 | Dehumidifiers
Runs great but no water in bucket ,whats wrong
either there's no moisture in the house (especially if you have an air conditioner), the coils are not cold enough, or there's no air flow across the coils. if the latter is the case, clean off the rear coils, clean off the front filter (or if no filter, the fins), and see if the fan is working. cleaning the condenser coil fins in the front would also help with it not getting cold, if that were the problem.
Jul 29, 2009 | Fedders A7DH45B2A Dehumidifier
Ebac BD80 Dehumidifier Logo
410 people viewed this question
Top Ebac Dehumidifiers Experts
Bill Long
jasbo
jasbo
NOEL
NOEL
Are you an Ebac Dehumidifier Expert? Answer questions, earn points and help others
