Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
Seems like the jet arms are not rotating dishes are not getting clean
  • 901 Answers
Check with hand for free rotation. If OK the water pump is not getting ON or the pump is not developing pressure.
Posted on Sep 15, 2010
  • 93 Answers
SOURCE: Maytag jet clean
If the arm has a crack or is broke pressure will not turn it properly. Also check the rubber boot that seal the wash arm on the rear supply tube. If the rear supply tube holes are not sealing from inside with the rubber flap seal that will effect it also.
Posted on Jul 24, 2008
SOURCE: my maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Posted on Dec 21, 2009
  • 572 Answers
SOURCE: the bottom arm is not rotating and the dishes are
check the chopper assembly
Posted on Feb 08, 2010
Daniel S
  • 4323 Answers
SOURCE: The dishes on the top
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Posted on Dec 13, 2010
  • 250 Answers
SOURCE: My Amana Softsound 2 isn't
Check the nozzles of the arm themselves. if you found lots of gookl there maybe some inside the arms blocking the spray holes which cause it to spin
Posted on Jul 15, 2011
Dishes and glasses on the top rach are not getting clean-bottom rack is fine.
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Jun 14, 2011 | Kenmore Dishwashers
Siemans dishwasher model SE55A560GB/42. Upper rotating spray bar not turning but botton spray bar is rotating. Dishes are left with a gritty feel to them.
Check that the arm rotates freely when spun by hand, then check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Apr 13, 2011 | Dishwashers
Dish not realy not clean leves film on them same soap as alwayes
Hi. Check that the arms are spinning. Something maybe jamming arms like a knife or fork sticking below the basket hitting arm or check that the jets, particularly the end jets are not blocked. Easiest way to check if spinning is to rotate arms into a known position and start a cycle with dishes in machine. After say 1 minute open door and see if arms have rotated. Cheers. Slavious
Sep 24, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
Zanussi ZDT 6244 Dishwasher , wash cycle completes , all water drains out , but the dishes are not brilliant clean & dishes are still wet
Try cleaning all the jet orifices in the rotating vanes. Use tooth brush. Check for dish plate is touching the rotating arm in the wash chamber. Rotate by hand for freeness.
Mar 29, 2010 | Zanussi 24 in. DE6544 Built-in Dishwasher
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Dirty dishes
if water comes into machine then valve is ok.
open machine when in cycle and look to see if spray arms are rotating
if not, then take out and clean.
spray arms only rotate with water jetting out of angled nozzles at end and if these are blocked then no rotation and poor wash
Sep 07, 2008 | Dishwashers
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
My Bosch dishwasher model #SHU43C05UC/14 drains well and has enough water(I replaced the inlet water valve already),but not washing the dishes clean especially the top rack.What could be wrong?
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Jul 14, 2008 | Dishwashers
Whirlpool ADP5966 washer tablet stiil in door
probably that spray arms are not rotating - to check, open the door when in operation and see if arms move. if not moving, usual cause is debris in spray arm jets. (arms only rotate thro water coming out of angled jets at end.) remove arms and clean for which you need patience
Apr 20, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
55 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
