Question about Troy Garden
My troybuilt riders wants to choke off and back fire while mowing in high grass. it does not increase rpm during higher torque requirements
    President:
  • Troy Master
  • 1,545 Answers
This sounds like a problem with the throttle governor, but I would also check the valve lash if its an OHV machine.
Posted on Sep 15, 2010
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
P0300 code
sounds like you have checked a lot of things if it was mine I would do new intake gaskets, I had a 2002 Sonoma I did a lot of what you did and every time I gave it back to owner a few days later lite was on and p0300 I did intake gaskets and its been good 2 yrs now,not sure what gaskets you got but gm use plastic ones I got new gm ones and they were aluminum type call gm dealer parts good luck
Mar 05, 2015 | 2005 GMC Sierra 2500HD 4WD
Troy Bilt XP self propelled mower
Normally an indication of poor air flow. Replace air filter. Clean outside of carb with carb cleaned to ensure choke is free to operate. Go real slow in tall grass, some mowers don't have the torque to do tall grass, only use 1/2 of the deck width and have side discharge open.
May 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Why do grass get stuck in lawnmower than it starts to turn off
This can be happening from a couple of reasons, first if your grass is too damp this will happen with almost any mower, wait till the lawn dries out before cutting, you may be cutting the lawn when it is too high, try cutting it twice a week maybe this will help, you may try to raise the cut setting eliminating the amount of grass clippings that you have accumulated, if you are mulching or using the bag be sure the chute is clear, and lastly be sure you are running at a higher speed to push through the terrain.
Happy Mowing!!
Jul 14, 2010 | Mtd 22" Yard Machine Push Mower
Idles fine with or without choke - cannot
Few suggestions(if not checked already):
Holed or incorrectly seated diaphram?
Timing advance?
I Presume you have checked already the air correction and needle jets too.
Please get back to me if you require further asssistance.
May 23, 2010 | 1999 Yamaha Xv 250 Virago S
Yamaha xv 1100 virago
To me it sounds like the coil is breaking down and not working at higher RPM's. You can take them off and have them tested at a service shop.
Dec 11, 2009 | 1994 Yamaha XV 535 Virago DX
Revers reves hi rpm.
Your reverse gear is the strongest single gear in your transmission it is not a high speed gear ut it s a high torque gear a if your car was heavily loaded or towing a trailer you wold require the higher torque for backing up
Jul 09, 2009 | 2001 Ford Windstar
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Cuts out and backfires
adjust the valves, this should solve the problem,
Apr 22, 2009 | Garden
Hesitation or stumble during acceleration
take your car for a tune up
if they are carburetor type motors you may need your carbie cleaned and a tune up
if you clean it your self with carbie cleaner it may increase in idle speed this is nothing to worries about it is a simple adjustment
with a carburetor type motor they tend to idle higher when their cold this is the automatic choke kicking in and normally it should happen till the car is a bit warmer and the accelerator has been depresses
although a car should idle at 800 rpm my paddok car dose when it is cold it idles at 1200rpm i like it this way as the car warms up quicker as i will not drive a car while it is cold
hope this helps
ricko
Oct 20, 2008 | 1989 Nissan Pathfinder
Garden Logo
43 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
