Question about HP Photosmart C6180 All-In-One InkJet Printer
We have error code 0xc18a0206 with our photosmart c6180
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
4 Suggested Answers
  • 1456 Answers
SOURCE: hp photosmart all in 1
Hello
Turn off the printer and open the cover where the ink cartridge is located.
Remove the print cartridge from its slot. Look for a sticker on the cartridge stating it is the right HP print cartridge. If it is the wrong type of cartridge, or if the cartridge has been refilled, replace the cartridge with the right HP cartridge..
Remove the cartridges again and unplug the printer. Dampen a lint-free cloth with water and gently wipe down each one of the cartridges. Avoid touching the nozzles or the electrical strip on the cartridge.Wipe from the top of the contact to the bottom. Do this for each contact Place the cartridges back into the printer and turn the machine back on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridges and check to make sure the electrical strip along the bottom of each cartridge is not damaged or ripped. If the cartridge is new, make sure the plastic protective tape has been completely removed. Place the cartridges back into the machine and turn it back on.
This should clear it.
Posted on Nov 06, 2010
vonnielsen
  • 169 Answers
SOURCE: I recieve Ink System failure
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Posted on Feb 04, 2011
mercadoarvin
  • 384 Answers
SOURCE: i have an HP Photosmart
Welcome to Fixya.
Here's how to resolve this issue :
HP Photosmart Reset
Basically, this error denotes "Ink System failure" and can be resolved by Printer reset. Follow the easy steps and you should be good to go.
Thanks for using Fixya.
Posted on Aug 20, 2011
0xc18a0206 error
ink system prime failure- the printer is no klonger able to hold pressure in the ink tubes- suggest you replace ALL PRINTHEADS in one go ( the problem may lie in just one printhead or the tubes themselves
If the prinhead replacemnet doesnt wotk then a new set of ink tubes and heads will be needed- this costs about the same as three new c6180 printers and is not worth the money- sorry for thew bad news
Jan 20, 2014 | HP Photosmart C6180 All-In-One InkJet...
I have an HP Photosmart C6180 i get error 0xc18a0206
Welcome to Fixya.
HP Photosmart Reset
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0206 for HP Photosmart 3310 All-in-One
Hello and Welcome!
The error
0xc18a0206 is mostly occurred in HP printers
To solve the error code
0xc18a0206, Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
But if u face still this error then printer service required.
In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Thank you for using FixYa
Apr 19, 2011 | HP Photosmart C6180 All-In-One InkJet...
Ink System has failied. Error 0xc18a0206 on HP Photosmart 6180
Press *(star) and # (hash) together on the printer and let go.
Key 1 then2 then3
Press the right arrow key until the onscreen menu shows System Configuration
Press OK
Press right arrow key until failure status is displayed
OK again
I think there was another OK after this but not sure????
Keep pressing cancel til you get back to the main menu then
Unplug from power for 1 minute then plug back in
Power back on.
Mar 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 ink system failure error:0xc18a0206
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures (0xc1....) the printer was having. A similar fix may apply to other printers. acca299.jpg
Oct 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
I Have an HP c6180
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 15, 2008 | HP Photosmart C6180 All-In-One InkJet...
I have an HP D7360 printer. I receive the error code 0xc05d2281. can you help?
I have a HP Photosmart C6180 All-in-One printer. When I try to print I get error code Oxc05d2281 on the printer scren. I have replaced all the carriages with new one. Please tell me how to fix this problem.
Thanks,
Estella
Jul 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,302 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
