I have a toshiba tecra 8000 after wiping it and installing xp i cant get the av out to pick up tv. i have downloaded all drivers and there doesnt seem to be any probs when i look on hardware profiles.do i need to set anything do u no or install different driver.any help much appreciated.
p.s. i use laptop for karaoke so need 2nd tv for grfx.
thnx dennis
SOURCE: Driver required NETWORK CONTROLLER for Toshiba tecra m2
Here is Toshiba download page.
Input Tecra M2 and windows version details and download netwrok driver.
SOURCE: how to install XP in toshiba Satellite L45-S7423 laptop
I am only going to say this once........vista is the best ........ believe me alot of people are afraid of vista ... I cannot understand why may I ask you SIR why are you changing from Vista to XP when they are both the same OS .......it is senceless ........exeriment man oh man experiment you will succomb.................
SOURCE: pioneer dvd-rw dvr-k17a
Are these drives you have fitted yourself, or been added as after market drives?
If so you have run in to the odd way Toshiba set their optical drives as master or slave, although this is generally and IDE #1 error.
To fix this you need to solder pin 45 and 47 together.
47 is the key pin here, as it controls whether the drive is in SLAVE or MASTER mode.
grounded, the drive is in MASTER, open, it is in SLAVE.
pin 45 is simply a grounding pin.
So you'll need to open up the drive, turn it over, and put a small blob of solder on the two pins next to each other - 45 and 47.
If they are original drives or used to work then uninstall the drives and the IDE controllers in Device manager and reboot, letting windows redetect and install the hardware. Also try reinstalling the motherboard drivers available from Toshiba's support site.
SOURCE: Keyboard layout
I am not sure exactly what you are asking,but this link well take you to Toshica Tecra A2 support page. It has drivers, manuals,support bulletins, all sorts of things you might find usefull. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=651096&rpn=PTA20U&modelFilter=A2&selCategory=3&selFamily=1073768664&selModel=651096|PTA20U#
i can not find the wireless lan driver for tecra m2
