Question about HP Compaq d530S PC Desktop
Memory update where can i buy 1gig memory for DV400PA#ABG
    Scholar:
  • 67 Answers
A good place to look would be www.crucial.com that is where I get all of my memory.
Here is the website for information on your systems memory.
http://h18000.www1.hp.com/products/quickspecs/11632_na/11632_na.HTML#Memory
Looks like you are looking for PC2100 PC2700 or PC3200 DDR Ram, Best Buy or Circuit City may even have what you are looking for. CompUsa may also be a good choice, as well as www.newegg.com which has very good deals on alot of computer hardware.
Hope this helps to solve your problem, Good Luck!
Posted on May 16, 2008
    Sergeant:
    Champion:
  • 230 Answers
Sorry 1gig memory for DV400PA#ABG is not available i think
Hi.. i have a Lenovo laptop model 7757 with Support DDR2 533/667MHz DRAM with dual channel... It has a 1gig memory and i want upgrade it to 3 or 4gigs.. is it ok if i'll put in 2gig memory in the other...
Yes, with this model, Mix and match is ok. Different sizes/speeds of memory can be used together as long as their specification are qualified by the systems. For instance, a laptop can use one 512MB and one 2GB of memory for the total of 2.5GB system memory. Mixing two different speeds of memory modules would result the system to run at the speed of the slower memory between the two modules.
Apr 12, 2011 | Lenovo 3000 Y410 Laptop
I'm using a Sandisk 1gig Memory Stick, but suddenly it has far less than 1gig to give. I mainly use this stick for my Sony Playstation Portable (PSP) for save files or such. Right now it has one 341.6mb...
because it requires that much space to write files to boot the games
if i were you, i'd save the games on your hard disk and format the 1G memory stock -- buy a larger capacity , such as 4G or 8G
please leave me positive feedback
Oct 16, 2010 | SanDisk 1GB Memory Stick M2 Memory Card
How to upgrade memory. I need module definition for 1Gig so I can purchase it.
You need a 512MB PC2700 DDR 333MHz SO-DIMM for a laptop (200-pin). The manufacturer I think doesn't specifically support anything over 512MB. But the RAM is standard and I doubt there is any need to buy it directly from Sharp. The laptop only has one upgradable bay so you may not be able to upgrade past 1.25 GB.
One of the memory covers is not removable, if I remember correctly, that is the one under the keyboard. So the one you update is a panel on the bottom.
Mar 11, 2010 | Sharp Actius AL27 Notebook
I want to add 1Gig Ram to istalled 512 Mb of Ram,Can I do this? NEC VERSA M160. Memory type DDR 533 Mhz PC2-400 200 pinSODIMM
Yes, of course you can do this with your own. The first things you should do are they:
You need to buy 1gb RAM which same socket to your old 512mb RAM. Be sure that the said RAM are compatible to your motherboard.
Dec 02, 2009 | Computers & Internet
I intend to install more 1 mega of memory, but motherboard not recognized it (one dimm 1gb pc3200 cl3 184-pin dimm). Of origin the PC it has been installing 2 dimms of 512 and I intend to add +1 dimm of...
The memory may not be compatible depending on the speed. Try taking out all the memory and just installing the 1Gig stick.. does it work?
If it does then the 1Gig stick is fine, but your PC probably doesn't like you mixing different types and speeds of memory.
If it doesn't work, the 1gig memory module might not be the correct speed your PC wants.
Sep 08, 2009 | Computers & Internet
Adding memory
chek your laptop first if it can accept the 1gig memory. if so then ask the supplier of your 2 pcs 512 memory to replace with 1 pc. 1gig memory. and also ask assistance to replace it.
Jan 08, 2009 | Toshiba Satellite R25-S3503 Tablet PC
Need more memory/have compaq presario/model s4000v. can i buy a 1mgb card and put in myself?
Yes ,you can buy 1 stick or 1GIG of Ram/Memory for this computer and its easy to ut it inside the unit so you shouldn't have any problem with it...
Hope that helps..........
Sep 18, 2008 | Computers & Internet
Ram install
1. bad memory
2. the motherboard doesnt support single sided and dual at the same time.
3. bios needs update
4. wrong slots for dualchannel?
Apr 05, 2008 | Intel Motherboard
Dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
More ram for my laptop
Never, NEVER buy a computer that is going to run Vista with less than 1Gig minimum!
2 Gigs of RAM is recommended for Vista.
To check on prices and the type check some online sites that sell memory
Most laptops have a removable door or hatch on the bottom where you can access the memory very easily. The modules easily clip in or out but never use force! (RTFM)
If you take it to someone, they'd probably charge $50 for labour, plus parts and the job takes 5 minutes.
Easily do it yourself, or find a teenager who's good with computers. Son, nephew, neighbour perhaps?
Before buying any new modules, check your laptop to see how many slots you have and what type of modules are in there now.
To upgrade to 2 Gig,  you will have to buy 2 new 1Gig modules, There's a 2Gig kit (1Gigx2) listed at one site for $80.
You would remove you current memory and install the 2 new 1Gig modules. Sell your 512 or make a keychain from it.
Oct 16, 2007 | Lenovo ThinkPad Z61m Notebook
HP Compaq d530S PC Desktop Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
