Question about ASUS P5PE-VM Motherboard
Asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
I wanna ask because i want to connect my front panel audio but i dont know wahat is the jumper settings because in my casing cord it have a L-out,L-ret,R-out,R-ret, gnd,mic-power and mic in. But in the manual it said i will connect Mic2_L, Mic2_R,HP_R Jack_sense, HP_l then AGND, PRESENSE # , MIC2_JD HP_HD can anyone help me?Thanks!!
  • 2 more comments
  • Anonymous Jun 06, 2008
    I have the same problem, the Case conector names are nothing like the ones described on the Mobo manual... I have almost the same conectors as you, I got Mic- power, Mic-Ret, MIC2, and that stuff... I was sucessfull only on making the front audio work, but still, when I remove the front audio Headphone conector the back audio wont always start, it only starts sometimes...
  • Anonymous Nov 05, 2008
    HOW TO CONECT FRONT CAEL
  • Anonymous Jan 22, 2009
    audio front panel setting
  • KSAcha Jan 26, 2009
    I have the same problem, but when I try the blog link, it is not there. Could you re-post your answer? I am trying to hook up 5 individual wires from the front panel audio to the 9-pin Audio1 connection of a M863G V1.5 Motherboard. When I did this, I can get the headphones to work to use Skype and to listen to sound, but now that is the only way I can hear sound. My rear hookups no longer work, which is where my speakers are attached. I do not have a headphone jack on the rear, or I would us it.
F_AUDIO <==> CASE
1- PORT_1L == MIC_IN
3- PORT_1R == MIC_PWR
5- PORT_2R == R_OUT
9- PORT_2L == L_OUT
-------------- OTHER SIDE ------------- (case wire)
2- GND
4- GND (other)
6- R_Return
8- key
10- L_Return
Posted on Mar 29, 2009
If the problem dont have any connection with hardware failure like: wrong jumper, bad headset, etc.
here's the answer:
right klik on SoundMAX Control Panel > Preference
on Speaker Setup choose Stereo Headphones.
Just like that.
asusatiyo@gmail.com
Posted on Feb 28, 2009
مشكورررررررررررررررررر
Posted on Nov 08, 2008
Me2
Posted on Aug 23, 2008
    Champion:
  • 207 Answers
Jumper setting for audio panel? i didnt get tht one
Posted on May 22, 2008
    Problem Solver:
  • 5 Answers
Try the link http://www.asus.com/P5PE-VMmotherboard
For find best solution.
Please Rate me if this information helpful for u.
3 Suggested Answers
  • 164 Answers
SOURCE: i wanna ask because i want to connect my front
I hope this helps...
Posted on Sep 14, 2009
bad_theta
  • 31 Answers
SOURCE: asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
Look this picture below, this is ASUS P4VM front panel.
Hpe its solve your problem....
Posted on Jun 01, 2009
Trying to find sound chip so i can restore my sound on my computer. i loaded windows 7 professional and i have an intel asus p5pe-vm mother board. need help please
This is just simple way. Just connect your front panel audio plug connector with your mother board audio socket.
In your motherboard there are several chassis-mounted functions. For your help i add a motherboard layout image.
Jul 03, 2016 | ASUS P5pe-vm Motherboard Intel 865g Lga...
How to connect power supply to p5pe -vm motherboard
There are two power connectors required from an ATX switch mode power supply.
A 20 pin ATXPWR connector and
a 4 pin 12 volt ATX12V connector
If you want a copy of this motherboard manual , please click on this link to download a copy :-
http://www.manualnguide.com/dl/9172/
Oct 09, 2010 | ASUS P5PE-VM Motherboard
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
Apr 30, 2010 | ASUS P5PE-VM Motherboard
How do I install the font usb to a ASUS P5PE-VM motherboard?
see mannual and find front panel usb connector on mainboard insert usb connector in it..
Apr 01, 2010 | ASUS P5PE-VM Motherboard
How to connect audio from motherboard p5s800
It is Asus P5S800-VM motherboard. Download the manual from Asus, click the link provided;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
You'll need to download and install Adobe reader to view the manual;
http://www.adobe.com/products/reader/
Turn to page 1-29. Section 11. Front panel audio connector (10-1 pin FP_Audio1). Notice there are two jumpers. One across pins 9 and 10. Another across pins 5 and 6. Pin one is marked, AGND and pin two is marked MIC2. ECT.
This is default setting when using the rear audio jacks. You can not run rear audio and front audio at the same time. (So pick one or the other). To run front case audio remove the jumpers and connect the I/O cables to the FP_Audio1 pins. There is a work around. You can buy an adapter that will split the audio from the rear allowing you to connect secondary audio and mic ports. Open the link provided;
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40422
You can buy these locally. To connect the FP_Audio remove the jumpers and connect the I/O cable to FP_audio pins. Use Adobe reader and zoom in. You'll find each pin is marked.
Cheers'
Mike
Mar 08, 2010 | Computers & Internet
Nov 26, 2008 | ASUS P4S533 Motherboard
Front audio in casing
The front panel audio for this board is labelled FP_AUDIO and is on the bottom left hand side of the board. See page 39 of the following; http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5PE-VM/e2609_p5pe-vm.pdf They're all labelled correctly. In your case, L-out - Mic2_L, L-ret - Mic2_R etc
May 29, 2008 | ASUS P5PE-VM Motherboard
Audio
Hay jake,
goto page 1-27 in the Asus P5PE-VM manual.
There is a diagram of the pin-outs for front case audio/sound connector.
Mike
May 26, 2008 | ASUS P5PE-VM Motherboard
Asus p5pe-vm
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
"GND" = GND
May 15, 2008 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
5,869 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
