Question about Acer TravelMate 4001LCi Notebook
Bad hard drive what do I replace it with - Acer TravelMate 4001LCi Notebook
  • 942 Answers
If you have an extra laptop in your house, try to use hard drive. You may consult for a computer technician in dismantling the old HDrive and installing the new Hdrive. Another option is to call Acer for request for Hard drive replacement...
Posted on Sep 14, 2010
Pri master hard disk s.m.a.r.t. status bad, backup and replace press del to resume
Hard drive is bad or is going to fail soon.
Solution
Backup your information and contact the maunufacturer of the computer or the hard drive for replacement or additional help.
In some very rare cases the S.M.A.R.T. implementation on your computer may have issues of its own and may need to be patched before replacing the hard drive.
If I am receiving the S.M.A.R.T. error, is it ok if I continue to use my hard drive and do not replace it?
As stated above, S.M.A.R.T. is designed to detect upcoming failures in the hard drive.
While it is possible that the hard drive may not fail for several months, it is still inevitable that the hard drive will fail.
It is ok to continue to use the hard drive, however, we highly recommend that if you are still under warranty that you consider getting the drive replaced before your warranty runs out.
hope this helps
Sep 20, 2012 | Western Digital WD AV WD2500AVJS hard...
Bad Hard Drive - Toshiba Satellite A665-S5170
I suggest you back up your hard drive right away and have the hardware tested for possible replacement.
Sep 18, 2012 | Toshiba MK6465GSX) 640 GB SATA II Hard...
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
1.
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
Keep clicking with red light on, computer can't see it
The hard drive is dead. You will need to replace it.
Mar 23, 2011 | Toshiba MK8025GAS Hard Drive
Disconnecting when copying large files (about 1gb and above)
that means it there are bad sectors on the hard drive. search for Hirens utility boot disk with google and and download the software. After you downloaded it you will have to write the files to a cd. Then boot up with the disc and select Hard drive tools or HDD tools, then select hard drive re-generator to detect and repair bad sectors if there are over 500 bad sectors then replace the drive.
Feb 25, 2011 | Toshiba MK1234GAX 120 GB ATA-100 Hard...
The hard drive is bad I need to replace this one for my Dell Laptop. Any suggestions
you are stuck getting a Dell replacement part for the laptop. It is the only way to be sure of getting the correct part. the Dell Service manuals are an excellent source for explaining how to remove the existing hard drive and replacing it.
Are you sure the disc is bad?
Dec 14, 2010 | Fujitsu MHW2060BH 60 GB SATA Hard Drive
The hard disk data base will be rebuilt. AN error occured during the rebuild. The disk must eb formated
Sounds like there are bad sectors on the hard drive. Try quick formatting the hard drive and see if it goes all the way thru, if it does then try saving games on it and reloading the saved games, if it does then the hard drive is good. If it doesnt then the hard drive is bad. If you can't get the hard drive to format then that means the hard drive is bad and you would need to replace it.
Dec 05, 2009 | Sony Playstation 3 (PS3) Console
Smart drive failed during diagnostic test
Bad sectors are starting to show up on the hard drive. Thats what the smartdrive program is for, its checks the hard drive to see if there are any bad spots or potential bad spots on the platter inside of the hard drive.
It will definitely have to be replaced. Replace it with a new one and if you can't then at least replace it with a known good used one.
May 12, 2009 | Gateway GT4024 PC Desktop
Bad hard drive?
the hard drive is damaged. install a new hdd and connect the old one as a secondary so you can extract your files after you reload the new one.
Mar 28, 2009 | E-Machines T3065 PC Desktop
Can i replace the default hard drive with any brand hard drive?
Well the replacement drive should be the same interface. i.e. if its an IDE drive then you'll need an IDE drive if its a SATA drive you'll need a SATA drive! regards, babb
May 07, 2007 | LaCie (300773) 1638.4 GB Hard Drive
Acer TravelMate 4001LCi Notebook Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
