Question about Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
Vent below clock puts out alot of heat - Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
  • Frigidaire Master
  • 43,501 Answers
That is the oven vent and it will throw alot of heat when the oven is on... that is very normal operation...the oven needs to be vented to for various reasons...
This can be a great benefit in the winter time but is very uncomfortable in the summer...so limit the summer use and use it like crazy in the winter...
heatman101
Posted on Sep 14, 2010
What does it mean when a dryer starts to tick like a clock
the ticking sound you hear is the timer motor.this is normal on timed dry.on auto dry you should only hear it when the heater is turned off.if the dryer shuts off and will not start after 20 to30 min. the motor has over heated and stopped to prevent over heating.venting is the no.1 cause of this.the vent system needs to be checked first.if it is a magic chef,admiral,or maytag under a few years the part below the lint screen needs to have all that lint removed every 6mo.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
There is no heat blowing when I select to have the heat blow on feet
sounds like a problem with either the dash unit, which is my guess electronic, or one of the servos that control the vent selection. there are two or three servos under your dash that control the airflow. when you select a position. the servo knows where to clock itself to select that vent. if the servo is dead, you get no operation from the vents. if the a/c unit has a malfunction, there could be a vent selection problem.
Nov 13, 2013 | Air Conditioning and Heat for GMC Terrain
When should em. heat be used on a thermmostat setting?
anytime your below the workable temp of your heat pump, so say your heat pump is putting out 70 degree air at the vent its time to switch. no sence in over working your heat pump
Jan 04, 2011 | Honeywell Programmable Thermostat Heater
My dryer DLE 2514W does not dry the clothes enought, we have to put it on for a second time to get them all dry. Seems to be alot of heat but doesnt dry the clothes
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
Dec 23, 2010 | LG DLE2514 Electric Dryer
Time clock has stoped working
Below are the removal instructions from my website www.autoclockrepair.com. I also offer a very reasonable repair service.
1997 - 2001 Honda CRV Clock removal Instructions
The vent bezel assembly needs to come out prior to clock removal.
Follow these 4 steps
1. Using a wide,thin blade such as a putty or butter knife, pry the
assembly up a little at the bottom until it pops out and slightly.
2. Pull the bottom out as it clears, and the top of the vent bezel
assembly will follow.
3. Once you have the vent bezel out, remove the electrical plug from
the clock.
4. Unscrew the two phillips screws that hold the clock in place.
Mar 21, 2010 | 2000 Honda CR-V
My lower and upper oven wont heat up
since either one is not working id say the clock assy is bad. we replace alot of btm oven baking elements ., but your clock is what sends power to the bake elements . so suspect clock. not a cheap repair
Sep 19, 2009 | Maytag MER6772 Gemini Electric Kitchen...
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Not getting alot of heat
you have a vacume leat to the heater unit and that is needed to switch the blend doors and if you have rear heat you could have an air bubble in the lines.
Jan 09, 2009 | 1995 Dodge Caravan
Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
157 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
