Question about Westinghouse Electric TX42F810G 42" LCD Monitor
Set will not turn on from back or with remote
    Problem Solver:
  • 5 Answers
Have you checked the Fuse?
Posted on Sep 21, 2010
  • psychobobtb Dec 23, 2010
    The fuse is grayed out (not clear glass) on this model (at least mine) so you actually have to remove it and shake it to hear if it's bad, that's all that was wrong with mine
I am told to go back to the TV set-up procedure and turn off CC?
Use either the remote "menu" or "setup" button to get to the settings for the TV.
Feb 05, 2015 | Seiki Brand original TV Remote control...
How to program this remote.
Hey mate is there a set button on your remote? or similar type of command, if so, turn the tv on by its main on/off button on the tv itself then stand back and point the remote at the tv, now press the SET button down for a few seconds, if you see a flashing light on your remote this means it is searching for a IR signal, cool now just keep pressing the on/off button on the remote say every 2 seconds, as soon as your TV turns OFF press the SET button on your remote and hopefully it should be tuned in and you can use the remote to turn your TV back on and play with menu and stuff. If this worked dude you can join my... getting a remote to work easy club .
May 23, 2013 | Televison & Video
Conia clcd 4210 remote only turning TV on and off
If it is an original remote with functions for the TV or other equipment the button on it that selects for TV, Cable, DVD etc may be in wrong position.
Also--many sets will if power loss do this when turned back on---unplug set from power and wait a while and plug back in to see if set returns to normal.
A few sets (read owner manual) have a feature for locking key or most functions on remote and front controls (or side) of the set.
Apr 07, 2012 | Televison & Video
I need step by step instructions to program the codes into my One For All universal remote URC-4220 to my JVC tv.
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
Feb 12, 2011 | One For All URC4220 Remote Control
How to use nikon ML-L3
Set the camera's shooting mode to one of the remote modes. Quick-response remote fires the shutter when you press the button on the remote. Delayed remote gives you two seconds to hide the remote behind your back before firing the shutter.
To set the D90's shooting mode, press the shooting mode button (the overlapping rectangles to the right of the LCD panel on the top of the body) and turn the main command wheel on the back. Quick-response remote shows a picture of the remote control unit, the delayed remote shows that and the clock (the same symbol used for the self-timer).
The remote mode is cleared whenever the camera is turned off. Since monitoring the infrared port consumes battery power, the camera may turn itself off before you take a shot. To prevent this, change custom setting #C5 to something more appropriate.
Oct 11, 2010 | Nikon D90 Digital Camera with 18-105mm...
IR Remote control 103781
OK first and foremost not all tvs are supported by Dish remotes. This is especially true of combo units bbut here is the easiest way to program the remote if the tv is supported:
Press and hold the clear tv button on the top of the remote until all buttons across the top light up.
Now press the smallred tv button and release it.
The top tv button should be lit constantly now.
Now press the arrow up key slowly until the set turns off.
Once it has press the arrow down button once and then the arrow up button to see if tv turns on.
If it does press the pound key and release.
The topmost tv buttton will flash three times.
You are now ready to press the SAT key on the top of the remote and watch tv as usual controllling volume etc with the remote.
If the set turns off but you can not get it to turn back on turn the set on manually and start the process again- it will not go back through the codes you already had tried.
If you notice the tv button flashing rapidly it means you are at the last code and need to go back the other direction or that there is no code for your set.
If the set turns off but will not turn back on then you have a partial code which will not perform properly. Thanks for using Fix Ya.
Mar 12, 2009 | DISH Network IR Remote Control
Need remote code for mitsibusi tv
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Philips Magnavox Learning Universal Remote
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Play station 3 dvd remote pairing instructions.
OK I FIGURED IT OUT!!! First turn off the system(ps3) make sure that you take the batteries out of the remote. Then when you turn it back on go straight to system setting, setting accessories, setting blue tooth device. AND THEN IT WILL TELL YOU TO HOLD DOWN THE START AND ENTER BUTTON DOWN!. Don't forget to put the batteries back into the remote. It took like 3 seconds.
Jun 20, 2008 | Sony Blu-ray Remote for PlayStation 3
Westinghouse Electric TX42F810G 42" LCD Monitor Logo
131 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
vimal
vimal
Clyde Chisale
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
