Question about Abit AL8 Motherboard
I updated my bios and cleared the bios on a Abit AL8 motherboard and it now has a 00 code and wont start up can you help me
    President:
  • 2,571 Answers
If you have damaged the bios then all you can do is try and re flash it.
A damaged bios usually means its new motherboard time
Posted on Sep 14, 2010
How can i reset bios on the fsb 1066 motherboard
Just look for the silver battery. Either remove battery and replace, or look for jumper (closest to battery with one pin showing, and two covered by the jumper) Remove the jumper and place over middle and previously uncovered pin, then move back to origional position.
Hope this helps
Wayne
Tech Rehab
http://techrehab.t35.com
Aug 11, 2010 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
My ABIT AW8-Max motherboard is showing an error "83", the manual I got of ine does not explain much other than saying "save all data in stack back to CMOS"! I dont really know what i need to do to fix...
Error message: 83h, Save all data in stack back to CMOS. 84h. Initialize ISA PnP boot devices.
First try clearing the cmos jumper on the motherboard. You will need the manual to help guide you. If you no longer have the Abit manual for the AW8-MAX motherboard you can download it by opening the link provided below; http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AW8-MAX&fMTYPE=LGA775&pPRODINFO=Manual
Click on the blue arrow to start the download.
You will also need WinZip to uncompress the zip file.
Download Winzip @ this link; http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Than you'll need Adobe reader to view the manual. Download and install Adobe @ http://www.adobe.com/products/reader/
Open the manual to page 2-8. Follow the instructions to clear the cmos. (Wait 30 seconds). Reset the cmos jumper back to normal. Boot you're system and press the Delete key on you're keyboard to enter the bios. Turn to page 3-1. Once the bios/cmos has been cleared the cmos resets the bios back to default settings. You will have to change some setting depending what is connected to you're motherboard.
When finished save and exit the bios. The system will auto restart. If you receive the error massage again than you'll need to replace the cmos battery. If after replacing the battery the error message still returns the last option would be to flash the bios/cmos with the latest bios. You'll find the bios file and bios utility/firmware from the Abit link below;
Cheers'
Mike
Mar 02, 2010 | Abit AW8-MAX Motherboard
What is the 'EE' Error code on the board mini display?
From ABIT WEB site:
http://www.abit.com.tw/faq/code.html
E0~EF Boot clock initial programs 00->EF Memory damage 1. Clear CMOS 2. Change memory 3. Send to RMA at last
Now, try to clear CMOS and/or change memory RAM.
Oct 18, 2009 | Abit IT7 Motherboard
Post code 99 in motherboard abit al8
check your motherboard's owner manual. Try removing the processor/ram/video card to see if that will give you any clues.
Sep 30, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
ABIT AN7 MAINBOARD HANGS @ POST CODE 90
I had the same problem, the bios is corrupted, try a blind bios update or if it doesn't want to, you must do a hot flash update.For more details google search for award bios hot flash.Or dump it and buy a new one.A hot flash worked for me for this mb and an Epox 8rda+,i also have backup bios chips now.Your chip is a Winbond,4 mb capacity.
Hope this helps, SSVik
Mar 23, 2009 | Abit AN7 Motherboard
Abit kr7a-133r morherboard will not post At first, it would not post every now and then. I would need to turn off and on 2 or 3 times,and then it would run fine. after a couple of months it got worse, I...
I take it you have the same type of memory[matched in pairs]. I had an asus board that did the same thing. I started the way most builders do when they bench test, I sarted with just 1 memory stick, l [left 1 rom in] and removed everything I could. With the Dell that started to act up I cleared the CMOS over night with the jumper in the clear setting. I was able to get the Dell to work, I ended up selling the Asus board and the guy who bought it said he cleared CMOS and replaced the battery and it fired right up. My first Abit board[NF7-S] came with no manual or drivers disc. It's used but one thing I can say is Abit really didn't look like it's site was much help. I am just about to test it. It does sound like a device problem. You can go online, if you updated your BIOS it may cause problems but I'd also look at the updated BIOS to see if there is a update with this problem listed. One last thing, if you have extra cables try them to see if it is the hdd cable, thats happened to me also.
Feb 26, 2009 | Abit KR7A-133R Motherboard
160 gig sata hard drive that keeps on failing
hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Abit th7raid motherboard-160GB HD cannot recognize-needs flashing-out of my depth!
Hi coonster,
Abit TH7 Raid driver.
Windows inability to see all of your hard disk drive is not a motherboard issue.
It’s a windows issue. ( I suggest you use the hard disk drive software from the manufacture’s web site). Most allow you to download software that allows you to create a bootable floppy disk. Boot to this disk & setup the drive in a dos like window.
Once completed you can now boot to the windows CD. Do not allow windows to format
the drive.
That is what the manufactures disk will do for you. Install windows & please update it fully. Windows should see all of the 160GB after updating.
If you feel you need to update the bios, feel free to do so.
Follow Abit’s instructions on how to update the bios from this link;
http://fae.abit.com.tw/eng/download/bios/index_old.htm#486
If you have never downloaded a bios file or drivers from this site it can be a bit confusing. You’ll need to high-light the entire link below, than right click once to open the pop-up window. Than left click copy. Open internet explorer. Right click once in the address window & left click past. Than press the enter key on your keyboard. The site has a timer on the left side of the page. You’ll have to wait for it to reach zero.
Than a yellow bar will open across the top of the page that says, (To help protect your security, Internet Explorer blocked this site from downloading files to your computer. Click here for options...). Right click once on the yellow bar & left click download file. Create a folder on your desktop & name the folder " Drivers". Download the file named " infinst_enu.zip" into the driver folder. Us any uncompressing program & uncompress the file keeping the files within the driver folder. The action of uncompressing the *.zip file will create another folder named " Disk1".
http://www.nodevice.com/driver/download.html
To download the Abit TH7 Raid bios is done like the instructions above. For this bios file you’ll need to do the same with the link below;
Abit TH7 Raid bios file name " th736.exe ".
http://www.updrivers.com/getbios/Motherboard/Abit/TH7-Raid-BIOS/6187.html
Please retype verification code: "enter code listed on site".
Press enter.
Again create a folder on your desktop & name it Abit bios.
You will not find any drivers, bios or manuals directly from Abit. They no longer support this motherboard.
Mike
Nov 07, 2008 | Abit KT7A-RAID Motherboard
Abit AL8 Motherboard Logo
71 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
