Question about Dell Dimension 4500 PC Desktop
My computer starts to load and when it gets to the blue windows xp screen it stops and does not load into windows.
  • naytz
    naytz Sep 14, 2010
    are you getting any error messages when it does not load to windows? any recent software changes you made on the PC for example if you have installed a new software before this happen.what are the steps you have done so far to try fixing this.any inputs will be valuable in giving you the resolution.thanks!
  • deangelis4 Sep 14, 2010
    no error message. It just stays on the windows xp blue screen
    Scholar:
  • 120 Answers
Turn off your computer by holding down the power button (10 sec.)
Turn the computer back on and Hold down the F8 button at the top of your keyboard, until the start up menu shows, Then select "Last known Configuration that worked"
If that does work you can repeat the steps and try system restore if you have it enabled.
If still unable to load you would need service, or to reinstall windows
Posted on Sep 14, 2010
    The F8 button doesn't seam to work. It stillgoes into the blue windows xp blue screen. Guess its the OS. I guess I will have to have serviced.
  • naytz
    naytz Sep 16, 2010
    dont hold the F8 button rather continously tap it when you boot up the PC.choose the option there that says safemode.it will ask you to log-in like your normal desktop screen.you can try doing a system restore to a date before this happen.access system restore do>click start>all programs>accessories>system tools>system restore.
My Acer gets a Blue Screen on startup.
i wold do a system repair on the notebook to see what that would do you would have to use the cd disc's that came with the computer or the one that has the windows xp loaded on to the disc.
Apr 28, 2017 | Acer Aspire One D250 16GHz Intel Atom...
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
I keep getting a blue screen when loading windows xp
without knoiwing the motherboard number its not possible to give a definate answere but i would say the board is driver locked to Vista or above this being the case you cannot install winXP that we all know and love
Apr 26, 2010 | Intel Motherboard
I bought lenovo G550 last week. It came with Windows Vista. I want to install Windows XP on it. I have found that lenovo has driver for windows XP so that will make my life easy :-) But when I try to...
you are most likely getting a BSOD with a stop error code of 0x0000007B which is caused by the Windows XP CD that you are using doesn't have the SATA Hard Drive controller driver needed to recognize and utilize the hard drive. If Lenovo has XP drivers for this model then they should have a SATA driver (roughly 394k) that will need to be loaded FROM A FLOPPY DISKETTE during the boot to XP. (XP Requires the driver to either be slipstreamed into the CD or loaded from a floppy diskette. Trying to load the controller driver USB or a different CD will not work)
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
Jan 11, 2010 | Computers & Internet
I recently tried to install a new WD320Gb HD and windows XP won't load. I loaded it to the drive from another computer and Windows won't successfully boot up. I get a Stop: 0x0000076B (0xF7946640,...
You installed the 320GB drive into another system & installed windows XP. Than removed the drive & installed it into another computer!
All of windows internal drivers for the first install will not function in the second. (Windows XP is going nuts).
You have to do a fresh install while in the system you want to keep the drive in. This is why your getting the stop errors & blue screens.
You must have a reason of why you did not install the 320GB drive into the second computer for the XP installation?
Care to provide the why?
Mike
Apr 26, 2009 | Biostar M7NCD Pro Motherboard
Dell laptop won't boot even after clean install of xp
your windows prolly crashed because your hard drive is going bad, and thats why your getting error messages when reinstalling.
Feb 26, 2009 | Dell Inspiron 1150 Notebook
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Dell Dimension 4500 PC Desktop Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
