Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer will not fill with water, but the washer runs full cycle, pump runs but no water is in the machine does spin cycle thinking a pressure switch is bad
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test
to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Posted on Sep 17, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
SOURCE: I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Posted on Jan 25, 2010
Testimonial: "Thank you. You gave me enough evidence now to get a new washer. Any recommendations? Most reliable front loaders."
heatman101
  • 43501 Answers
SOURCE: my maytag neptune stacked washer will not spin. It
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 26, 2010
MAH3000AWW Does not spin fast enough on spin cycle Clothes are still full of water when done.
hi there ..sounds like your appliance is not spinning at all........(a) check if your drain pump is working correctly..(simply fill water and turn to drain)..(b) possiblity that the clutch drive mechanism is badly worn and needs replaced
regards Sir Galahad
Aug 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Will not go through the wash cycle
sounds like it is the transmission in bottom of washer is cheaper to replace washer than have a service man repair
Jul 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
only 2 or 3 real problems with this machine, bad machine controller( behind console) although lights on are sign that its good,
Either the pump is clogged and not draining water so it will never spin let alone spin full speed with water in tub, i also doubt that because it seems that s there just water within the clothes and not a tank full of water,
which leaves the last Major issue with machine and that's the motor controller, not telling the motor to spin.. could also be a bad motor but i really doubt that all....
This is a funny machine because depending on when it was made (serail number denotes its age) im looking up the model and your manual states that you have a 3rd yr to 10 yr part warr on the motor, Well on earlier models you cant replace the motor itself it comes as part of a kit, "NEPTUNE REPAIR KIT" which also includes the motor control board. reason i mention that is I"m able to get a motor controller covered by warr(as an authorized maytag technician) if the model will take the neptune repair kit, sure youll need to pay service and labor but the a part would be covered.
Mar 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
188 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
