I have a Samsung DVD Recorder and VCR modle DVD-VR 357. Wnenever I insert a DVD into the tray and close the door, the unit displays the "LOAD" message and, after a short while, the door opens and the DVD ejects from the machine.
  • 10,594 Answers
Put an audio disc in player and play it, if unit plays then go to last track then first track to make sure optical laser lens moves freely inside player then check again with dvd disc playback.
If player does not play audio cd as well then optical lase block sounds defective and need to be replaced by professional in your area.
And if unit playback audio disc but wont play dvd disc then clean optical lens manually with good quality cotton swab that might fix the issue as some time thin layer of dust on lens causing trouble to read disc data.
Hope these info will help you.
Thanks.
Posted on Sep 14, 2010
Insert disc.....
May be looking for a firmware update disk. Try looking on the panasonic website for firmware updates for this unit. Burn the file to a disk and put it in the machine and let it load.
May 29, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
My Samsung DVD/VHS recorder the DVD won't close after playing DVD
Never force it, just use the remote.
If it won't stay in, unplug the unit and wait a while.
I think we get viruses from the TV signal which might be temporary (hopefully).
Apr 24, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray is stuck in open position. Pressing close button results in slight jerking motion of tray followed by display of "close", then "load" ...
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Mar 05, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have a model dvd-vr 357 samsung dvd-vcr player recorder to hook up to a 2002 hitachi, and i must have it hooked up wrong.the tv is a 52 inch large screen h.d. the dvd -vcr turns on and when play is...
You need to use the video and audio outs located in the rear of the samsung player, or if you want to use the rf connector(atenna in) on the tv you need to select analog channel 3 or 4 to get a picture through, you can down load an owners manual at wwwretrevo.com.
Feb 03, 2010 | Televison & Video
It won't recognise a blank dvd.......its says "The disc cannot be played....please check the disc" I HAVE A DVD VR 357
check the disc in your PC if this finds it as a blank dvd then possible play head error.
Use a DVD+/-RW and use Imageburn to full erase then try this one in the recorder this may work if not a possible motor failure on the spindle
Jan 17, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
DVD disk tray will not open at all
had the same problem the mechanism for the door opener is faulty.........waited for 2 months to be finally told by samsung part is no longer available......wonderful back up service isnt it. Luck have it I had an extended warranty and getting it replaced with a LG combo
Jun 03, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Samsung DVD-VR375 says "load" but tray for DVD/VCR won't open
I think you have problem in DVD deck assembly the owner manual won't help you if still under warranty bring back to Samsung if out of warranty you can buy the DVD deck from Samsung and replace by yourself
Let me know if you need part number for the DVD deck
Dec 04, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
I have a Samsung DVD -VR 357 combo unit and i can't record
I have the Samsung dvd-vr 357. I have had a couple problems with it but I called samsung and they walked me through fixing it each time. I don't know if you have tried this or not but that is my suggestion. The last problem I had was copying from vcr to dvd. I got audio but no video. Problem was it was on dvd when i started it, it should have been on vrc. It should be set on whichever one you are recording from. Hope this helps someone.
Nov 12, 2008 | Samsung DVD-VR357
Samsung dvd-vr 357 remote code for comcast
The HD cable remote --> Code 21075
May 16, 2008 | Televison & Video
Go video DVD/VCR recorder Model number VR-3845
First make sure you are using a quality disc like:
memorex Brand dvd-r.
Dec 25, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
53 people viewed this question
 Grubhead
Grubhead
